click on the engine
- Fox
Re: click on the engine
16 Jul 2022 20:05
... Stupid question : how to find an exhaust leak ?
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
17 Jul 2022 01:04
The following user(s) said Thank You: Fox
- kevski
17 Jul 2022 01:17
I had a clicking like this on mine, it would on the odd time disappear, it took a good lot of head scratching to work out it was camshaft binding in number 4 cam cap, it would appear that in the past a cap had been changed and one corner would bind slightly, it had a gap of around 150 microns when the other 3 bolts were nipped down, shimmed that corner and no problems since, i found out by turning all of the lobes off a spare cam and putting in the engine, putting caps on and loosened the cap bolts in turn until i found the culprit.
17 Jul 2022 01:34 - 17 Jul 2022 01:35You need to get as close as poss (don't burn your ear) and listen, you can try carefully tightening the headerpipes but after listening to the video I don't think it is an exhaust leak... Stupid question : how to find an exhaust leak ?
PS: the only stupid question is the one you don't ask
Last edit: 17 Jul 2022 01:35 by Wookie58.
- willemZ900
- Z1B 4 ever
17 Jul 2022 11:44
Recently I had a leak on exhaust 4 and that was a very hard ticking noise. After tighten the screws a little the ticking was over
The following user(s) said Thank You: Fox, Wookie58
