click on the engine
- Fox
click on the engine
16 Jul 2022 15:35
Hello all,
i post here because i need help.
On my kz1000 ltd 1978 i have a click sound. I check the valve adjustement and all are at 002 to 003 (point forward)
Am i too tight ?
here is the video for the sound :
any help will be appreciate
Am i too tight ?
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
Re: click on the engine
16 Jul 2022 15:48
The video won't play for me but have you checked you don't have an exhaust leak where the headers join the head (this also makes a "clicking" sound)
- Fox
16 Jul 2022 15:49
This is how i adjust them
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
- Fox
16 Jul 2022 15:51
you mean the 4 copper gaskets ?
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
16 Jul 2022 15:53
Yes, if they don't seal completely you get a "ticking" or "clicking noise" that speeds up as you increase the engine speed
The following user(s) said Thank You: Fox
- Fox
16 Jul 2022 16:01
Yes i ever check that
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
16 Jul 2022 18:18
What RPM is your motor idling at ???
Try turning it up a little ,, What happens
Did you adjust the cam chain tension ???
16 Jul 2022 18:24
Your valve cover gasket in the video needs to be replaced. Please check all the cam chain idlers gears and guides off any kind of wear. The rubber damping ring part between the bearing and the cam gear can be get brittle of aging and the parts do disintegeting. The cam chain then drive off set the center line and get rub against the cam chain tunnel of the head and cylinder walls.
16 Jul 2022 18:37
I see light puffs of smoke when the camera is near #4 plug. I don’t think it’s the valves. Check the case breather. Open up the oil fill cap, and listen there. You my have a bent exhaust valve. What’s the compression numbers. I think you have the wrong cam cover gasket. Somewhere it blow by, either rings or a valve.
16 Jul 2022 18:40
Check to make sure the spark plugs are sealing. I also see the puff of smoke when you show the front of the engine. It looks like smoke is passing through the air cooling tunnel near #3 plug.
- Fox
16 Jul 2022 18:46 - 16 Jul 2022 18:49
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
Last edit: 16 Jul 2022 18:49 by Fox.
- Fox
16 Jul 2022 19:22
What do you think about my cam chain tensionner 12048-001.
I know this one is worn.
In more i have one Damper rubber that is broken 92075-289
between the 2 metal plates i didn't replace it ...
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
