Starter
- SmithDubs
Re: Starter
03 Jul 2022 12:11
I hooked the starter to some jumper cables after taking it out - same issue - I need a used one - if I need used one - if I can’t find I’ll buy new - I’m not rebuilding folks - don’t want to will not - if you have a starter lying around let me know - REMINDER - I’m not rebuilding - no more post about me rebuilding -
Re: Starter
03 Jul 2022 12:22 - 03 Jul 2022 12:23Have you looked into getting yours re-built, it's more reliable than used ( remember the part you get will also likely be 40 years old) and significantly cheaper than new. I don't know where in the world you are but in the uk this is normally around a week and approx $100 or lessI hooked the starter to some jumper cables after taking it out - same issue - I need a used one - if I need used one - if I can’t find I’ll buy new - I’m not rebuilding folks - don’t want to will not - if you have a starter lying around let me know - REMINDER - I’m not rebuilding - no more post about me rebuilding -
Last edit: 03 Jul 2022 12:23 by Wookie58.
Re: Starter
03 Jul 2022 14:21I hooked the starter to some jumper cables after taking it out - same issue - I need a used one - if I need used one - if I can’t find I’ll buy new - I’m not rebuilding folks - don’t want to will not - if you have a starter lying around let me know - REMINDER - I’m not rebuilding - no more post about me rebuilding -
Sorry I tried.
- Injected
Re: Starter
03 Jul 2022 14:32
No follow up in : Classifieds/Wanted?
1978 KZ650B2 modified project
- daveo
Re: Starter
05 Jul 2022 19:52I hooked the starter to some jumper cables after taking it out - same issue - I need a used one - if I need used one - if I can’t find I’ll buy new - I’m not rebuilding folks - don’t want to will not - if you have a starter lying around let me know - REMINDER - I’m not rebuilding - no more post about me rebuilding -
I have a spare starter...if interested send a pm.
1982 KZ1100-A2/1170 sleeper 😀
