Starter
- SmithDubs
Starter
02 Jul 2022 16:24
Hey guys - Lookingfor a starter for my 82 Kawasaki KZ1100 A shaft- starter is bad!
Re: Starter
02 Jul 2022 19:05
Have you dismantled it? What do you mean when you say it's bad?
Re: Starter
02 Jul 2022 19:05
It is still available new from Kawasaki.
If you want used, I think all of the J engines used the same starter.
Are you sure it is the starter and not the starter clutch?
Re: Starter
02 Jul 2022 19:47 - 02 Jul 2022 19:55
Last edit: 02 Jul 2022 19:55 by SWest. Reason: add link
- SmithDubs
Re: Starter
02 Jul 2022 20:02
Won’t spin like it should - very weak. I do t want to rebuild (don’t have the skills) just need a used one - this one is trashed
- SmithDubs
Re: Starter
02 Jul 2022 20:03
I’m just checking before I bite the bullet and spend $230 - used will be better than the one I have!
Re: Starter
02 Jul 2022 21:08
Re: Starter
03 Jul 2022 01:03Do you have a voltmeter ? A bad ground will give the same symptoms. My fault finding guide in the FAQ section tells you how to check a starter circuit for connection problems. There is no worse feeling than spending a chunk of money and having the same problem when you push the buttonWon’t spin like it should - very weak. I do t want to rebuild (don’t have the skills) just need a used one - this one is trashed
Re: Starter
03 Jul 2022 04:30
Starters are one of the easier components to rebuild. As Steve said, it may only be the brushes. You can buy new brushes for a couple of bux.
- JR
Re: Starter
03 Jul 2022 07:58
And if you're taking the old one off the bike you may as well open it. Only 2 bolts. Just scribe a line where the top joins the main body. Mine didn't even need brushes. Just blew out the carbon dust and greased the gears in the bottom.
Re: Starter
03 Jul 2022 11:43
Stockers is a good source...
www.stockers.com/index.php?dt=KS-20
Re: Starter
03 Jul 2022 11:59Worth doing your voltage checks first, it only takes about 20 mins and costs nothingDo you have a voltmeter ? A bad ground will give the same symptoms. My fault finding guide in the FAQ section tells you how to check a starter circuit for connection problems. There is no worse feeling than spending a chunk of money and having the same problem when you push the buttonWon’t spin like it should - very weak. I do t want to rebuild (don’t have the skills) just need a used one - this one is trashed
