Starter
  • SmithDubs
  • SmithDubs's Avatar Topic Author
Starter
02 Jul 2022 16:24
#869778
Hey guys - Lookingfor a starter for my 82 Kawasaki KZ1100 A shaft- starter is bad!
  • hardrockminer
  • hardrockminer's Avatar
Re: Starter
02 Jul 2022 19:05
#869779
Have you dismantled it?  What do you mean when you say it's bad?
  • TexasKZ
  • TexasKZ's Avatar
Re: Starter
02 Jul 2022 19:05
#869780
It is still available new from Kawasaki.
If you want used, I think all of the J engines used the same starter.
Are you sure it is the starter and not the starter clutch?
  • SWest
  • SWest's Avatar
  • 10 22 2014
Last edit: 02 Jul 2022 19:55 by SWest. Reason: add link
  • SmithDubs
Re: Starter
02 Jul 2022 20:02
#869784
Won’t spin like it should - very weak. I do t want to rebuild (don’t have the skills) just need a used one - this one is trashed
  • SmithDubs
Re: Starter
02 Jul 2022 20:03
#869785
I’m just checking before I bite the bullet and spend $230 - used will be better than the one I have!
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Starter
02 Jul 2022 21:08
#869786
Have your battery load tested first. Don't ask me how I know.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Starter
03 Jul 2022 01:03
#869789
Do you have a voltmeter ? A bad ground will give the same symptoms. My fault finding guide in the FAQ section tells you how to check a starter circuit for connection problems. There is no worse feeling than spending a chunk of money and having the same problem when you push the button
  • hardrockminer
Re: Starter
03 Jul 2022 04:30
#869791
Starters are one of the easier components to rebuild.  As Steve said, it may only be the brushes.  You can buy new brushes for a couple of bux.
  • JR
  • JR's Avatar
Re: Starter
03 Jul 2022 07:58
#869801
And if you're taking the old one off the bike you may as well open it. Only 2 bolts. Just scribe a line where the top joins the main body.  Mine didn't even need brushes. Just blew out the carbon dust and greased the gears in the bottom.
  • Nessism
  • Nessism's Avatar
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Starter
03 Jul 2022 11:59
#869811
Worth doing your voltage checks first, it only takes about 20 mins and costs nothing
