KZ900 Pushrod Not Moving
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: KZ900 Pushrod Not Moving
09 Aug 2021 11:12
#853454
I fixed your pictures
 Please next time click the insert all tab to complete their  installation
  • Lebowski
  • Lebowski's Avatar Topic Author
09 Aug 2021 12:07 - 09 Aug 2021 12:08
#853455
So, after reviewing the procedures, I am confident that the cable and lever have been adjusted correctly. I'm just not getting any movement on the push-rod. So, could the spring plate be stuck against the friction plates? I'm about to lay it on its side and check it open. Any tips before I do this?
Last edit: 09 Aug 2021 12:08 by Lebowski.
  • Mikaw
  • Mikaw's Avatar
09 Aug 2021 12:30
#853456
Dealers choice. The female post of the spring plate could be corroded to the male post of the clutch hub. The pusher could be froze up in the tunnel where the push rod lives. At worst you might need a new clutch cover gasket but that’s it just to take it off. Most time just leaning it on the side stand is enough to keep 90% of the oil in the engine.
also good JIS screwdriver and maybe a impact driver to get the screws out. I think there are 2 that are longer. Make sure you watch length
  • Lebowski
09 Aug 2021 12:44
#853457
Thankfully, the previous owner replaced all the screws with allen head screws. About the only useful thing the previous owner did.
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
10 Aug 2021 06:49
#853499
On most motor covers the longer screws generally go into holes with dowels.  If in doubt, place the cover then completely insert all the screws without turning them.  They should all stand proud by the same amount, 1.5CM or so.  Differences due to length errors will be obvious.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
  • Lebowski
13 Aug 2021 17:49
#853740
So, I opened up the clutch cover and all the plates are stuck together. I can't get them apart with my hands so I'll have to pry them apart somehow. I suspect this is my issue. I'm just going to go ahead and get a rebuild kit and gasket of z1. Otherwise everything looks good. The push rod is moving smoothly and engaging the little push mechanism at the other end of the ball bearing.
  • Mikaw
  • Mikaw's Avatar
13 Aug 2021 17:58 - 14 Aug 2021 10:16
#853742
Was the clutch cover also stuck to the plates? You could soak them in engine oil to see if they will release
Last edit: 14 Aug 2021 10:16 by Mikaw. Reason: Spelling, not the best at it.
  • SWest
  • SWest's Avatar
  • 10 22 2014
13 Aug 2021 18:49
#853748
Was the clutch cover also stuck to the plates? You could soak them emote oil to see if they will release
Or gas
  • Lebowski
14 Aug 2021 17:26
#853825
The clutch cover was not stuck to the plates. Now that I'm thinking about it, does it really make sense that I would have issues with the push rod not moving if all the clutch plates are stuck together?
  • Mikaw
  • Mikaw's Avatar
14 Aug 2021 17:33
#853826
I’d think not. If the cover wasn’t stuck to the fiber and steel lump, it should still move away from the plates. The plates fuse might not be the problem but a result of the clutch not working.
  • Mikaw
  • Mikaw's Avatar
14 Aug 2021 17:43
#853829
You said the rod was moving smoothly, is that with the clutch cover off? an old racer trick was to use valve springs as clutch springs. I never tried it but you may have the wrong springs.
  • Lebowski
15 Aug 2021 10:02
#853848
Yea, rod moves smooth without cover. Haven't tried putting it all back just yet. I guess they could be valve springs, but I'm kinda doubting it. BTW, got all the clutch plates separated with some oil soaking. Tha js
