Oh sh%#t monument
- Zilla
Oh sh%#t monument
20 Mar 2021 13:52
What’s the best route, adjustable gears, back stock? Hopefully I can drop the oil pan and find the tooth.
1986 KZ1000P
2005 Vmax
2005 Vmax
- Polish
Re: Oh sh%#t monument
20 Mar 2021 14:10
Oh shoot is right! Good luck!
JL
JL
1979 Honda CB400T Cafe Racer (current ride)
1982 KZ750 LTD (current project)
20 Mar 2021 14:50
Questions
How many miles on motor ?
How long was it running with a missing tooth ( If you have any idea from engine noises )
Stock parts should be fine , I would be worried about damage or excessive wear to the cam chain
I would inspect all the cam chain components for damage.
20 Mar 2021 15:02
Agree with Streetfighter. Check every crevice in the head too. Who knows how far it might have been flung when it broke?
You might be able to drop an extendible magnet down the chain space to try to pick up the broken tooth. I would try that first, especially if the engine is still in the bike. It's a bitch to drop the pan and clean the gasket properly before replacing the pan.
- Zilla
20 Mar 2021 15:15Questions
Little over 30,000 miles. I was literally trying to tune a set of 34 flat slides as it was idling I blipped the throttle a couple times then it started running rough then shut off , thinking it was the carbs tried restarting it , it wouldn’t start and sounded funny so I shut it down and started looking, the only reason i thought bout checking the timing was because the way it sounded when it shut off.
1986 KZ1000P
2005 Vmax
2005 Vmax
- Zilla
20 Mar 2021 15:17Agree with Streetfighter. Check every crevice in the head too. Who knows how far it might have been flung when it broke?
ok, didn’t think bout dropping the magnet, no damage stood out other than the missing tooth. The motor is still in the bike, I saw that gear and closed it up and had to walk away for a bit
1986 KZ1000P
2005 Vmax
2005 Vmax
- DFIGPZ
20 Mar 2021 16:53
I would not trust he chain after this.
1984 750 Turbo
- Zilla
20 Mar 2021 17:03I would not trust he chain after this.
I thought bout also, I have never split any cases, and I’m not sure bout a chain with a master link
1986 KZ1000P
2005 Vmax
2005 Vmax
20 Mar 2021 18:08Original owner 78 1000 LTD
The following user(s) said Thank You: Zilla
- Zilla
20 Mar 2021 18:24
That’s what I’ve been researching now, I have two different service manuals a clymer and a older Kawasaki one, just trying to sike myself up. Lol
1986 KZ1000P
2005 Vmax
2005 Vmax
20 Mar 2021 19:02
Pitstop Performance in Florida
has a step by step guide on there site
Engine building ,Bottom of page , One for top end and one for bottom end
Lots of good tips
Lots of good tips
The following user(s) said Thank You: willemZ900, Zilla
- Zilla
20 Mar 2021 20:11Pitstop Performance in Florida
Lots of good tips
ill pull that up and look at it appreciate that. Thats who I got my 1075 kit from.
1986 KZ1000P
2005 Vmax
2005 Vmax
