Oil Coolers
- Dr. Gamma
Re: Oil Coolers
10 Mar 2021 09:12 - 10 Mar 2021 11:15
I made it. The lower part of the oil cooler bracket is a copy of the KZ1000S1 oil cooler bracket. The top part of the bracket I copied from something Muzzy had on one of the '81 Kawasaki Superbikes. I got pretty good at fabbing up all kinds of brackets over the years. Plus I had a welder extraordinaire that did all my welding back then. Some of the rubber gromments I used are the battery box gromments from H1 and H2 Kawasaki triples!!!
Here is where I got most of my ideas for making my oil cooler bracket.
1986 RG500G 2 stroke terror.
Last edit: 10 Mar 2021 11:15 by Dr. Gamma.
The following user(s) said Thank You: 750 R1
- Dr. Gamma
Re: Oil Coolers
10 Mar 2021 09:24 - 10 Mar 2021 10:08
Nope!!!! The top parts of my oil cooler mount are NOT Z1 battery hold down straps. I started with 1 inch x .080 4130 moly. Heated and bent into shape. The hard part was getting the 180 degree bend where the rubber straps fit into to match. It took me 4 or 5 different pieces to get 2 matching straps. I used to hang around a welder that built Pro Stock drag race car chassis' That is where I picked up all my metal fabrication skills from. He even made the comment one time that he should charge me for all the tips and information I picked up just from watching him work with metal!!!
Last edit: 10 Mar 2021 10:08 by Dr. Gamma.
- 750 R1
Re: Oil Coolers
10 Mar 2021 14:39
Thanks for the reply, I actually already bought 8 battery box grommets to use for a bracket before I saw yours. I should be able to fab up something similar...
Thanks
Thanks
Re: Oil Coolers
10 Mar 2021 16:09 - 10 Mar 2021 16:19
I bought a cheap GPZ1100 UT oil cooler and fittings from evil bay for my engine set up and some new oil cooler lines and ear hose clamps.
It´s a low buget task with lying around parts for testing and will finished next.
Oil flow and oil hose routing
Last edit: 10 Mar 2021 16:19 by Scirocco.
Re: Oil Coolers
10 Mar 2021 18:41
Those oil lines don't look "Mickey Mouse" to me. :whistle:
- urankjj
The following user(s) said Thank You: slayer61, KennyJ
- KennyJ
Re: Oil Coolers
14 Mar 2021 16:35
Does it matter which oil line goes to the top of the cooler? I always thought that the output line goes to the top and the return line to the bottom of the cooler
Re: Oil Coolers
14 Mar 2021 16:47KennyJ wrote: Does it matter which oil line goes to the top of the cooler? I always thought that the output line goes to the top and the return line to the bottom of the cooler
Most coolers will have the lines on the top or bottom depending how you install it .
Few if any are set up for side fittings , so no top and bottom lines
Look at the coolers shown above
- zed1015
Re: Oil Coolers
15 Mar 2021 05:23
If you mount the cooler with the lines at the top you gain a little extra oil capacity and quicker circulation on start up as the cooler retains its contents when stood.
Just remember to drain the cooler of used oil when doing oil changes.
Re: Oil Coolers
15 Mar 2021 07:10
Anybody heard of using a VW oil cooler? just throwing it out there. I vaguely recall seeing something in the old KZR archives.
Re: Oil Coolers
15 Mar 2021 09:04martin_csr wrote: Anybody heard of using a VW oil cooler? just throwing it out there. I vaguely recall seeing something in the old KZR archives.
Most car coolers should work
At one time we would cut coolers out of Ford cars that were used for power steering
- Bugeater
Re: Oil Coolers
23 Mar 2025 14:57
How has anyone run the oil lines on a KZ/Z1 with a Turbo setup? I have a Big Block (1327) that runs a Mr. Turbo setup. The Junction currently feeds oil to the turbos that would normally be used to run lines to a cooler. I want to add a cooler for obvious reasons, but not sure how to plumb oil lines correctly.
75 Z1B Turbo...
1327cc Wiseco 10.25:1
Mr. Turbo (Mikuni 42mm HSR draw through setup)
Dyna 2000 controller with their miniature series 3ohm coils
74 Z1A 1105cc...
74 Z1A 1105cc...
