Cam chain choise
  • willemZ900
  • willemZ900's Avatar Topic Author
  • Z1B 4 ever
Cam chain choise
29 Nov 2020 07:28
#839166
I see two sorts of cam chains for my Z , endless (tsubaki heavy duty on Z1 enterprices) and one with a link. The one with the link is much cheaper as the Tsubaki but how is the quality. Are there members on the forum who used the link chain? Last time, 38 years ago it was nessesary to split the case of my Z and i used an original endless Kawasaki chain, but now i think thats not nessessary because the bike runs well, only some oil leakage on the head ( i think O ring problem). So if i gonna change the gaskets, piston rings and all the rollers i also want to change the cam chain , but not split the the case.
  • hardrockminer
  • hardrockminer's Avatar
Re: Cam chain choise
29 Nov 2020 10:27
#839183
Splitting the cases is an easy task. You just need to take time to clean all the bolt holes. I changed chains on both my bikes and went with the endless loop Tsubaki heavy duty. I would not want to break a chain while riding.
  • Dr. Gamma
  • Dr. Gamma's Avatar
29 Nov 2020 10:44
#839187
Play it safe and put the endless cam chain in.
If you ever saw what a snapped cam chain does to all eight valves when it breaks, you would take the time and split the cases!!!!
Pay me now or pay a lot later.
1986 RG500G 2 stroke terror.
The following user(s) said Thank You: willemZ900
  • kevski
  • kevski's Avatar
29 Nov 2020 11:05
#839188
I have the type with the link in mine, provided it is peened correctly there is no problems.
  • Nessism
  • Nessism's Avatar
29 Nov 2020 11:11
#839189
I've seen master links that use a clip. Those ones I'd stay clear of for sure...
  • DFIGPZ
  • DFIGPZ's Avatar
04 Dec 2020 14:48
#839375
DO NOT USE one with link !
1984 750 Turbo
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Away
  • Moderator
  • Moderator
04 Dec 2020 15:04
#839376
Endless HD for me only !!!!!!!!!!!!!!
  • willemZ900
  • Z1B 4 ever
05 Dec 2020 10:24
#839414
Thanks for all your advise, just bought an endless HD Tsubaki from Z1 enterprices.
Greetings from a cold and wet Netherland and nice christmas to you all
Willem
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
05 Dec 2020 21:00
#839452
Does anyone know of any potential clearance issues with the heavy duty cam chain? I thought I read someone mention that at some point, but can't find it now.
My dad's '74 Z1
'00 ZRX1100
  • zed1015
  • zed1015's Avatar
06 Dec 2020 01:46
#839454
DOHC wrote: Does anyone know of any potential clearance issues with the heavy duty cam chain? I thought I read someone mention that at some point, but can't find it now.
There's no clearance issues when using HD cam chains.
You may be confusing that with the fitting of 'O' ring chains to the early z1/900 which requires spacing out the sprockets a few mill to stop it chewing the trans cover.
  • Dragbike_Mike
  • Dragbike_Mike's Avatar
06 Dec 2020 05:39
#839461
willemZ900 wrote: Thanks for all your advise, just bought an endless HD Tsubaki from Z1 enterprices.
Willem
You can't go wrong with the HD Tsubaki camchain - best choice as others have mentioned.
And, a Merry Christmas to you, Willem, from the cold and somewhat wet northeast U.S.!
Mike
  • Mikaw
  • Mikaw's Avatar
06 Dec 2020 08:53 - 06 Dec 2020 08:54
#839473
I’m a big rookie with engine building, I’ve been doing research and the Tsubaki HD seems to be the cats meow. Also Jim at Redline cycle claims the HD chain extends the life of the guide rollers.
Last edit: 06 Dec 2020 08:54 by Mikaw.
