Cam chain choise
- zed1015
Re: Cam chain choise
06 Dec 2020 09:48True! Chain stretch is the cause of sprocket tooth wear so a HD chain will remain in spec far longer.Mikaw wrote: Jim at Redline cycle claims the HD chain extends the life of the guide rollers.
That said as long as whatever chain is used is not allowed to become excessively worn the idler teeth will remain serviceable almost indefinitely with the main cause of failure being the rubber centers.
06 Dec 2020 12:31
My 2 cents on cam chains .
Anytime I crack a motor open and split the cases .
The motor gets a new HD chain installed.
Why ??????
Limited opportunities to replace the chain , as how often do you dig this deep into your motor.
HD chain ?? Hell yeah . Minimal cost to upgrade over standard chain
2nd why ???
If your cam chain is allowed to wearout.. and fail,, Motor is destroyed Head , valves junk, Pistons kissed . Maybe more / worse
Just my 2 cents
Why ??????
2nd why ???
Just my 2 cents
06 Dec 2020 18:20Street Fighter LTD wrote: My 2 cents on cam chains .
Why ??????
2nd why ???
Just my 2 cents
Yep!
