Spark plugs
- Dareniles
Spark plugs
11 Nov 2020 14:41 - 11 Nov 2020 14:48
Hi, can anyone tell me what size tap I would need to clean up the spark plug threads on a Kz750n1 spectre 1982? Thanks
Last edit: 11 Nov 2020 14:48 by Dareniles. Reason: Add photo
- Dareniles
- zed1015
Re: Spark plugs
11 Nov 2020 15:35
Yes! M14 X 1.25 mm
Re: Spark plugs
11 Nov 2020 16:10
A thread chaser would be better than a tap. It takes out less metal.
www.amazon.com/Lisle-20020-Limited-Access-Spark/dp/B008MFR2IS
The following user(s) said Thank You: SWest, BCScott, Dareniles
- Dareniles
- Rick H.
Re: Spark plugs
12 Nov 2020 05:48
Be careful how you use it....
Rick H.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
- Dareniles
Re: Spark plugs
12 Nov 2020 07:45
Hi, grease in the flutes and only start by hand till it finds the thread, you tube advice.
- Rick H.
Re: Spark plugs
12 Nov 2020 11:07
I back the tap up and out of the hole often to clean debris off the tap and re-grease if needed. The less junk on the tap the less chance of something getting in the bore. If possible use a tap handle to help keep the tap straight . I usually put the piston at close to TDC so I can peer in the hole with a pen light and see if any junk fell on top of the piston. Just don't bang your tap into the piston. If debris does fall in the cylinder you can try to vacum it out or use a long Q-Tip with a little grease on the end to retrieve the debris. Itty-bitty debris usually blows out, but big chunks can cause problems.
Good luck!
Rick H.
Good luck!
Rick H.
Rick H.
The following user(s) said Thank You: Dareniles
- ckahleer
Re: Spark plugs
12 Nov 2020 16:31
You can put a few greasy gun cleaning patches on top of the piston to attract metal droppings.
97 ZL600
94 VF750c
94 KE100
82 KZ305
94 VF750c
94 KE100
82 KZ305
- Warren3200gt
Re: Spark plugs
13 Nov 2020 05:15 - 13 Nov 2020 05:17
All sounds like a lot of faffing to me. Why not just use a reverse action thread chaser. Goes through the plug hole, expand it and unscrew it. It brings any cut material out with it and nothing can drop into the cylinder as the expander plate is the internal thread size.
www.amazon.co.uk/Sealey-MS003-Reverse-Ac...Thread/dp/B0086306NO
Last edit: 13 Nov 2020 05:17 by Warren3200gt.
The following user(s) said Thank You: Nessism, BCScott
- Rick H.
Re: Spark plugs
13 Nov 2020 05:33
Yeah it's a little more work than most people might do, but invariably two things happen in these instances. One is they occur at the worst possible time and second I keep forgetting to obtain one of these expanding spark plug thread chasers. With my luck I would buy one of these tools and would never have a need for it, or it would be so far in the future from when I bought it I would forget I had it. It does sound like a nice tool to have though.
Rick H.
Rick H.
Rick H.
The following user(s) said Thank You: Warren3200gt
- Warren3200gt
Re: Spark plugs
13 Nov 2020 06:08 - 13 Nov 2020 06:16
What they are especially useful for is cleaning any carbon out the threads after a colour tune. Don't know why colour tunes have such short threads leaving half the cylinder thread exposed to combustion gases. Use a colour tune alot more frequently than having to repair threads.
Last edit: 13 Nov 2020 06:16 by Warren3200gt.
