Z1R Camshaft End cap bulge.
- Rick H.
Re: Z1R Camshaft End cap bulge.
04 Jul 2020 06:09
Perhaps his problem is with the cam end plugs themselves. Are they installed correctly? Did he replace the old ones, or re-use them? He doesn't say, only that he replaced the gasket. If he did replace them did he use OEM or some inferior product that expands when hot and looks like it's bulging? Hard to say with no more info. I think you would need some serious pressure to get quality plugs to bulge in appearance no doubt if that happened they would blow out of the head.
Rick H.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
04 Jul 2020 07:51
Original post has NOT been followed up .
Im going to drop this from my interest until we get the feedback needed to assist this member
- 1980 Z1R D3
- A young gun with a taste for two-wheeled fun!
19 Jul 2020 16:02 - 19 Jul 2020 16:03
Hi guys, sorry for not following up, I got pulled away from the bike project by complete kitchen remodel at our summer home. Now that that's done, we can get back to it. Ill try to answer all the follow up questions you guys asked, and I really do appreciate all the help.
Oil type for that oil change. 10W40 Valvoline motorcycle oil purchased at autozone
Double checked the crankcase breather and the hose itself both are clear and functioning. Tested the breather by starting the bike and putting my finger on the hole, and felt the little pulses of air.
As to the plugs themselves I have no idea whether they're OEM or not, they do only seem to have an outside lip and not an inside one. There is some evidence that the valve cover was taken off previously, so they couldve installed new end plugs at that time. They also used a lot of nasty gasket sealer, gross, which seems to indicate that it leaked before. We bought billet aluminum plugs online that were going to use to replace the leaky ones. My personal theory is that the old plugs were somehow weakened by age, and started bulging and leaking out the bottom. The rest of the leaks are probably just due to the fact that the bike sat for nearly 30 years.
Thanks again guys
Thanks again guys
1980 Z1R D3
Last edit: 19 Jul 2020 16:03 by 1980 Z1R D3.
19 Jul 2020 16:32
Let us know how the new plugs work out for you
I use a little Gasketcinch under my aluminum plugs
- 1980 Z1R D3
19 Jul 2020 16:36
Will do, Ive got hondabond to put under the plugs. Now I've got to sort out all the other leaks, this is my first bike and im dying to learn how to ride it but it takes a lot of work to undo 28 years of neglect.
Colin
Colin
1980 Z1R D3
- VTEC
19 Jul 2020 17:001980 Z1R D3 wrote: Will do, Ive got hondabond to put under the plugs. Now I've got to sort out all the other leaks, this is my first bike and im dying to learn how to ride it but it takes a lot of work to undo 28 years of neglect.
Colin
Can't go wrong with Hondabond. I use it every day at work.
KZ1000-K2
ZRX1100
XR400R
ZRX1100
XR400R
- 1980 Z1R D3
30 Jul 2020 07:59
Update: the Hondabond in combination with billet aluminum end caps from johnny's vintage motorcycles in Ohio worked like a dream, no leaks, and changing the oil to hondas GN4 10w-40 solved most of our other leaks, thanks again guys.
1980 Z1R D3
- VTEC
30 Jul 2020 16:451980 Z1R D3 wrote: Update: the Hondabond in combination with billet aluminum end caps from johnny's vintage motorcycles in Ohio worked like a dream, no leaks, and changing the oil to hondas GN4 10w-40 solved most of our other leaks, thanks again guys.
Changing oil doesn't fix oil leaks.
KZ1000-K2
ZRX1100
XR400R
ZRX1100
XR400R
