camshaft chain tensioner tighten
- Fox
03 May 2020 12:32
Hello,
I'm looking for the good procedure for the automatic oem kz1000 ltd B1 cam chain tensioner :
How much do i must tighten the left screw please ?
Just by hand like here ? at 30.30 mn
Thank you
Fox
Thank you
Fox
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
- zed1015
Re: camshaft chain tensioner tighten
03 May 2020 13:29
Yes! it's only a 6mm bolt so nip it up by hand and the same with the lock nut.
around 8 ft/lb max.
around 8 ft/lb max.
The following user(s) said Thank You: Fox
- Fox
03 May 2020 13:36
What do you think of what i find on an other forum :
"Just loosen the bolt, and re-tighten it. Torque on the bolt is 35 -50 in-lbs. Then tighten the locknut."
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
- Fox
03 May 2020 13:45
Ok let's go for a stupid question :
Is this automatic tensioner
-"automatic when we ride" (so the spring will move himself over time to remove the slack )
-"automatic when we adjust it" ( (so the spring won't move anymore ones in place by me )
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
- zed1015
03 May 2020 13:56
It's not automatic so only moves when the bolt is loosened.
50 in/lbs is around 4 ft/lb.
8 ft/lb is the typical max torque for an M6 bolt.
I never torque them and just nip them by hand .
03 May 2020 14:10
You really need to find the instructions that are specific to your year and model bike.
Here's why I say this:
On my 1977 KZ650-C1 the cam chain tensioner automatically adjusts itself when the nut and bolt are loosened - BUT the cams MUST be in a certain position when this is done (which is described in the Kawasaki Service Manual), otherwise the tensioner will not be correctly adjusted and that can result in problems. The manual describes how to do this in a very simple fashion (it's very easy), but it is even easier to do it wrong if one doesn't follow the procedure. Later year bikes use different tensioners and procedures, so it is important that the procedure used is the correct one for the year and model being worked on. Ed
The following user(s) said Thank You: loudhvx, Fox, BCScott
- Fox
03 May 2020 14:21 - 03 May 2020 14:36
I never find the kz1000 ltd one...
I use the Kawasaki KZ 1000 (A2A-A3A_MKII-A4-D3_Z1R) '76 thru'79 - Service Manual
They have a same tensioner . The same one that we can see on the video posted before.
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
Last edit: 03 May 2020 14:36 by Fox.
- Fox
03 May 2020 15:00
Ok i think i have it :
i will set the engine at TDC, then loosen the tensioner bolt.
I will then tighten it by hand.
Fell free to post any more informations before i go back to work on it
Thank you
Thank you
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
- slmjim+Z1BEBE
04 May 2020 06:57
The tensioner plunger has a tapered flat that the tip of the lock bolt contacts. The plunger's taper is thicker at the jug end & becomes thinner toward the spring end.
Once the bolt is snugged onto that tapered flat, the plunger can't 'back off', 'cause the taper won't move past the tip end of the lock bolt. It can't move from a thinner part of the taper where it was initially tightened onto onto a thicker part of the taper.
It doesn't take much torque at all on the lock bolt to secure the plunger very securely. Like some have mentioned above, just snug it. & then snug the locknut. It's not a torque-critical fastener like head nuts, for instance.
An article written by Tech guru Kevin Cameron many years ago postulated that it's better to make some adjustments with the motor at operating temperature. One very specific example he mentioned is camchain tension. His position is that if the cam chain is adjusted cold, that due to thermal expansion of the entire case/jug/head assembly after startup the crank center and cam center(s) move away from each other during heating, resulting in the camchain being slightly over-tight. By how much? That's open to discussion but, it presents an opportunity for maintenance on a more subtle level. Even in the early days of the air-cooled Z motors, it was apparent that the camchain slider shoe at the front of the jugs was somewhat delicate & didn't tolerate overtightened camachains well at all. We've always made camchain adjustments hot.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
The following user(s) said Thank You: Fox, Rick H.
- Fox
04 May 2020 08:14
Awesome. Thank you very much for your time an explanation.
Have a good day
Have a good day
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
1977 kz1000-B1 LTD
- Rick H.
04 May 2020 09:33slmjim+Z1BEBE wrote: The tensioner plunger has a tapered flat that the tip of the lock bolt contacts. The plunger's taper is thicker at the jug end & becomes thinner toward the spring end.
Good Ridin'
slmjim & Z1BEBE
Thank you for the info, certainly makes sense if you think about it doesn't it? Better a tad loose than a tad tight IMHO.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
