- Thank you received: 87
Delkavic Dissapointment
- 9er rider
- Keep a cool tool
- riturbo
- Thank you received: 280
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
- Thank you received: 2746
- Dr. Gamma
- Thank you received: 676
1986 RG500G 2 stroke terror.
- bluej58
- Thank you received: 511
- ThatGPzGuy
- Thank you received: 385
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- perrykz1000
- Have a safe day !!
- Thank you received: 32
- loudhvx
- Thank you received: 1616
The Mac header for a 550 does not require removal, but it does feel and sound like a cheap system (because it is cheap).
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- 9er rider
- Keep a cool tool
- slmjim+Z1BEBE
- Thank you received: 732
Suspect you mean the 4 / 2 Jardine tuned system system.SWest wrote: ... I miss my cross over 2/1 Jardine "tuned exhaust".
A true 180⁰ tuned system with the classic, balanced look of two collectors, one on each side, that paired cylinders 1&4 into a collector @ 180⁰ firing order, and cylinders 2&3 into the other collector, also @ 180⁰. Exemplary street performance. Retained the centerstand, plus easy oil filter & drain plug access. The baffles produce a sweet, deep bass exhaust note without the irritating high frequency component that lesser systems failed to attenuate. The bends necessary to achieve four truly equal-length head pipes resulted in a tangled-looking, asymmetrical headpipe system that's an acquired visual taste. Too, the headpipes were single-wall, resulting in the chrome bluing somewhat at the first bends, something unavoidable on single-wall pipes even with optimum jetting. Overall, the Jardine 4/2 system weighs slightly more than 4/1 systems but, I never cared about a few pounds. The pleasant exhaust note, serviceability and aesthetics were & still are worth it.
Hooker also made a 4/2 crossover system that the headpipe crossovers were perfectly symmetrical at the cost of sacrificing equal length headpipes. I saw far more Jardine systems in the day than the Hookers.
After production of the Jardine 4/2 Z1 systems ceased I tried mightily to make the Jardine 4/2 system for a KZ1000 fit, but the headpipe bends were all wrong. Lacking the skill and/or funds for custom fabrication in the day, I gave up on fitting them to a Z1.
Rumor has it that after Jardine's acquisition by SuperTrapp, the original Z1 4/2 pipe jigs still exist, gathering dust someplace.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
An enthusiast's forum focused exclusively
on all things Z1, Z2 and KZ900.
- Rick H.
- Thank you received: 255
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
