Flooding and clutch slipping help
Re: Flooding and clutch slipping help
13 Jul 2019 19:19
Failing to adjust the valves will damage the engine; the clearance decreases with mileage and when the clearance is all gone the valves/seats burn. The manual calls for valve checks every other oil change for good reason. They are not optional. Poor hot starting and/or stalling is a classic sign of tight valves. Hopefully the engine is okay.
The following user(s) said Thank You: baldy110
- KzRyan
- Ryan
13 Jul 2019 19:33
It’ll be the first thing I check tomorrow morning.
1978 Kz1000 A2A. 1040 Weisco 10.25:1 pistons, VM 28ss carbs, Dyna S Ignition and coils, Moto GP Werks exhaust, Ikon Shocks, lithium ion battery, Always a work in progress.
1974 Kz400 - 16K miles - all stock
- baldy110
13 Jul 2019 20:22
What Nessisim said, you CANNOT tune / troubleshoot a new to you bike without first doing the basic maintenance which includes a valve clearance check / adjustment. By the way by the time too tight valves start showing symptoms the damage is already done. A lot of owners of these old bikes fail to do the valves because it's to costly or complicated for them. I've gotten numerous old KZ's with over 15,000 miles on them and been thru numerous owners that never checked the valves.
- KzRyan
- Ryan
13 Jul 2019 21:07
How often should the valves be checked.? If the manual says every other oil change. 6 k miles? When should the valve clearances be first checked on a new build / head assembly?
13 Jul 2019 21:13
I checked at 500 miles and found two tight ones.
- KzRyan
- Ryan
14 Jul 2019 09:51
Alright I have some results from checking clearances.
#1 ) ex/in .08mm
#2 ) ex .07, in .05
#3) ex/in .09
#4) ex .08, in .10
#1 ) ex/in .08mm
#2 ) ex .07, in .05
#3) ex/in .09
#4) ex .08, in .10
- KzRyan
- Ryan
21 Jul 2019 11:40
New gas cap fixed the problem. Didn’t want to end the post without a solution.
The following user(s) said Thank You: loudhvx, JR
21 Jul 2019 11:56
Yay! Thanks for the update.
- loudhvx
21 Jul 2019 16:28
One other thing to check since it's related to fuel flow is an inline filter. If you have a see-through, inline filter with a paper element designed for cars, you will get a similar problem of fuel starvation. The solution is to use a scintered-brass filter or metal-screen filter. Both of those are commonly available through motorcycle sources, but not usually auto-parts stores.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
The following user(s) said Thank You: KzRyan
- KzRyan
- Ryan
27 Jul 2019 11:32
That’s what I got. Had to amazon a large enough metal mesh clear filter. Works great! Unfortunately my new problem is that my rear caliper seized.. sooo onto another issue
- loudhvx
27 Jul 2019 12:51
Thanks for the update!
There's always something
1981 KZ550 D1 gpz.
Other links.
Other links.
