Valve Adjustment Measurements
- baldy110
Re: Valve Adjustment Measurements
28 Mar 2019 20:42
Yes, with the cams and tensioner off carefully rotate the engine counter clockwise while pulling up on the chain. If it's bound up you will feel the chain come up as you turn the crank.
The following user(s) said Thank You: lousankz
- lousankz
28 Mar 2019 21:08baldy110 wrote: Yes, with the cams and tensioner off carefully rotate the engine counter clockwise while pulling up on the chain. If it's bound up you will feel the chain come up as you turn the crank.
So this worked with the cams off, I was able to rotate the engine freely clockwise with the chain pulled up and it seemed fine. Got the cams back on and ran into the same issue. I’m tired so I give up tonight but I’ll spend more time on it this weekend. Thanks for the input!
1981 KZ750E
- lousankz
29 Mar 2019 09:29
I havent changed/drained the oil yet from the motor although all the leftover oil in the valve/cam area is gone via leaking down through the valves. Is there any chance it could be a lubrication problem? I am guessing not based on the resistance I am getting on the wrench when trying to turn the crank with the cams on, seeing as I am unable to move it at all (without literally standing on the wrench to see what I can break)
1981 KZ750E
Look into the spark plug holes to see if any valve collide with the Piston dome.
- baldy110
29 Mar 2019 15:45
If the engine turns over without the cams in place but won't with the cams in place can only be one of two issues. The cam chain is bound up on the crank or the cams are not timed right.
- lousankz
24 May 2019 13:25
Hey Guys! I am back with more questions again. I got the valves all spaced appropriately and the top end back together. She's running great for the most part but I have noticed what sounds like a "ting-ing" or ticking noise that rises and falls with the revs coming from the 4th cylinder, more specifically sounds like it's towards the exhaust side of the valve.
Has anybody heard of this happening? If I recall, #4 was a valve that had very little clearance before the valves were done so I am wondering if changing the valve seat that created an issue somewhere with exhaust side of the motor.
1981 KZ750E
24 May 2019 13:28
Check to make sure it isn't just an exhaust leak where the pipe and head meet. Ed
- lousankz
28 May 2019 08:53
Thanks for the reply, Ed.
Would changing the valve clearance cause an exhaust leak to start occurring? I believe that cylinder #4 exhaust clearance was nil before I corrected the valve measurements.
Thanks!
Thanks!
1981 KZ750E
28 May 2019 10:16
If you mean at the head it could be. If the valve itself is chirping it's been burned.
