Starter gear damper, is it needed?
  • Samminorwich
  • Samminorwich's Avatar
Re: Starter gear damper, is it needed?
28 Nov 2021 07:28
#858386
Have had mine removed I don't know the sequence of parts or tbe orientation of the damper DK I believe removed the rotor and broke the crank bolt off in the crank I think they must have done this because tbe alternator case was screwed onto the engine how else would tbey know , tbey said it was a barn find as is ?
anyways I gather tbere is a shim to go on first before before the damper my Honda vt500 didn't have this damper system
  • TexasKZ
  • TexasKZ's Avatar
28 Nov 2021 12:09
#858406
If you have a KZ900, it should look like this…..
www.partzilla.com/catalog/kawasaki/motor...erator-starter-motor
