Starter gear damper, is it needed?
  • MrFathead
  • MrFathead's Avatar Topic Author
06 Jan 2019 02:32
#796237
Hey guys I've been rebuilding my kz900 for the last few months and I am getting towards the end of it. I accidentally threw out my starter gear damper, part number 92075-192 or what ever size it was. I am having trouble finding a place to buy one and I am considering just assembling it without it.
My understanding is that that gear only moves when I am using the starter motor to start the engine, so even if it wobbles a bit it can't really hurt anything and once I am running it should make no difference. Has anyone ran their bike without one of these?
Re: Starter gear damper, is it needed?
06 Jan 2019 05:48
#796243
No eBay APP ID and/or Cert ID defined in Kunena configurationI would not leave it out. Here's one. Ed
  • martin_csr
  • martin_csr's Avatar
06 Jan 2019 07:22
#796252
I wouldn't want anything unnecessarily wiggling around, especially in regards to gear or sprocket teeth meshing.
  • MrFathead
06 Jan 2019 08:02
#796258
It's so annoying I can't believe I lost it haha. I will probably have to order that one you linked I will measure it up and check what size it needs. I need the bike running for the February mad max reunion so I might have to assemble it without the damper and just kick start it.
  • zinnco
  • zinnco's Avatar
20 Apr 2020 12:45
#823745
I see three different part numbers, 92075-192 / 193 / 194. In the same order, the designations 6.3T, 7.3T and 8.3T are shown. What do they signify?
1976 KZ900 LTD
1976 KZ900 LTD resto-mod TBA
1977 KZ1000 LTD 1075
1979 KZ1000 LTD 1075 / cams / 34mm carb
1978 KZ1000 Z1R
1978 KZ1000 Z1R 1075 /cams
1980 KZ1000 Z1R 2nd over
  • davido
  • davido's Avatar
20 Apr 2020 13:12 - 20 Apr 2020 13:13
#823749
I was reading about this last week. From what I remember,if you replace a certain part of the starter clutch you need to check the gap and use the appropriate spacer/washer. I think its more like a shim. Hence the 3 options.
If were talking about the same thing.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Last edit: 20 Apr 2020 13:13 by davido.
  • zed1015
  • zed1015's Avatar
20 Apr 2020 15:24
#823760
zinnco wrote: I see three different part numbers, 92075-192 / 193 / 194. In the same order, the designations 6.3T, 7.3T and 8.3T are shown. What do they signify?
They are the thickness in millimetres,
If you don't know which one you need then buy the thickest and lap down the lip on wet and dry paper until the gear stops being pulled round by the crank.
You need just enough clearance to allow the starter gear to spin freely without drag.
  • Samminorwich
  • Samminorwich's Avatar
19 Nov 2021 04:27
#858057
Hi what's the average thickness of the damper I assume it's the steel you lap down in size if too thick
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
20 Nov 2021 20:31
#858127
Apparently the space ranges between 6.3mm * to 8.3mm.***.  My KZ1100-A2 engine probably has a mid-range 7.3mm ** damper installed.
In the image below, the two dampers on the left measure 6.4mm, and the one on the right is 8.4mm.  These dampers may be similar on engines other than a J-model.
Note the Kawasaki *** identification detail molded into the rubber
The back flat side is metal.  IMO to reduce thickness, I would sand off material from the rubber edge which faces and rubs against the engine
1982 KZ1100-A2/1170 sleeper 😀
  • zed1015
  • zed1015's Avatar
21 Nov 2021 07:18
#858139
No! It's the rubber lip that needs reducing.
  • Samminorwich
28 Nov 2021 07:10
#858384
Hi got two dampers from the USA one std and one thick all I could get , how import is the shimming ?? Never shimed a rubber part before lol
surly it's just anti rattle at high engine speed not starting
  • zed1015
  • zed1015's Avatar
28 Nov 2021 07:19
#858385
It's mainly for anti rattle..
If too thick the rubber lip needs reducing just enough to allow the large starter gear to free wheel /remain stationary when the engine is running.
Too tight and the crank will spin the gear anti clockwise and drive the starter motor.
