Delkevic Stainless Exhaust
- rstnick
Re: Delkevic Stainless Exhaust
15 Oct 2018 17:42
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s (aka GPz750)
1978 KZ1000 project
CANADA
2000 ZRX1100
1978 KZ1000 project
The following user(s) said Thank You: perrykz1000
- old_kaw
25 Jan 2019 15:05 - 26 Jan 2019 07:27
Well, after getting sick of waiting for warmer weather, and with the addition of a small 250 watt electric heater into my little shed / workshop it was sunny and the temps topped at 32*F here in the lou soooo.. I got a couple of small projects done today. One being new tensioners / idler pulleys and new serpentine belt on my truck..
AND most importantly, reworked the Delkovic center-stand stop to move it away from the rear tire a tad bit. It was wayyy too close for my tastes as can be seen in the pic.
The stop looked slightly angled up around 10 *, and stuck out too far from the silencer. I put a framing square on it and scored the metal to a straight up 90* angle to the silencer bracket, then cut it off from the backing piece as carefully as I could, considering the metal cutting and grinding tools that I have available here. I used a pneumatic 3" cutoff tool that can do some major damage to some steel.
I changed the wire in my Lincoln mig welder to .023" ER308 stainless welding wire. (what a PITA that is lol)
It is / was pretty tricky getting a clean weld into that tight corner area because I was having trouble getting good penetration into both pieces of stainless with that big ole gas nozzle preventing me from getting in tighter, and ended up doing a "blob job" to get both pieces stuck down good.
A tig welder would have worked better on it. I'm glad it's under the bike rather than right out in sight on display.
As you can see, it did turn out good enough. I wish I had moved it further to the right, but this isn't too bad.
1981 Kawasaki Kz1000K1
Last edit: 26 Jan 2019 07:27 by old_kaw. Reason: typo's
- old_kaw
26 Jan 2019 07:33 - 26 Jan 2019 07:36
One thing to note on this exhaust, since the only mount is on the silencer, and the muffler support bushings are rubber bushing, the mount can twist in the rubber. Also with the slip together pipe joints and springs it can twist and change the position of the center-stand stop and silencer.. Which could put the stop into the tire sidewall. It is definitely something to keep my eye on. I noticed yesterday that the header collector is ~1" down from the oil pan after riding it a bit, where as this is where it originally was positioned.
Last edit: 26 Jan 2019 07:36 by old_kaw.
- Olajoe
- Free at last
26 Jan 2019 09:33 - 26 Jan 2019 09:34old_kaw wrote: I got it installed today, Perry. There goes my stealth bike.. I seemed to pick up an "escort" within half a mile from home while on my maiden voyage. No more coming home quietly. It does have a deep "knarly / throaty " sound, turning my mild mannered, docile bike into the monster it always has been. (it was lurking under that quiet, muffled persona.)
Terrific bike. It's a killer. Stock geared 0-60 and it just about owns. Muscle cars, sports cars, sportbikes, this 37 year old bike does not discriminate. I was at the gas station last week, a professional dressed customer parked in the next stall comes up to me and asks me how much I want for it. Well pal, if you gotta ask :laugh: I read through your thread and it doesn't appear any rejetting was done. I'm at high altitude with the kerker/ stock airbox/filter and 1up pilot, 2up mj and my bike will top out all of the max 85mph speedo quick. 0-60 will compress your cheeks like your blowing saw dust off yourself with the air hose . I understand delk says rejetting not required and know the same has been said about kerker but even at high alt my bike keeps pulling. Just throwing this out there. The rejet made it run cooler. Btw, I was just looking up a tach seal replacement, stumbled upon this delk exhaust while skimming the parts catalog, thought to check out kzrider and found your thread. So in way you've made it all come round full circle. Thanks, have a great day.
Last edit: 26 Jan 2019 09:34 by Olajoe.
The following user(s) said Thank You: old_kaw
- 650Dude
- Banned
26 Jan 2019 10:02 - 26 Jan 2019 10:02
I put mine on a few weeks ago. Here is video:
1977 Kawasaki KZ650B
1977 Kawasaki KZ750 Twin
Last edit: 26 Jan 2019 10:02 by 650Dude.
- Olajoe
- Free at last
26 Jan 2019 10:31 - 26 Jan 2019 10:36
Sounds bueno. And the fact that it does not interfere with the filter super super nice. Don't know about you guys but around here in the rockies these bikes/non oem exhaust w/baffle will stop other motorist in their tracks. Many times someone in front me even a guy on highly modified sports bike with the sawed off go-to-jail loud pipe stop to listen to my bike go by this is while the traffic light is green. Take the baffle out, and it's game over. Oh, in my previous reply is not to put the bikes hp up on a stage. Just to suggest that in stock configuration kawasaki just about nailed.. The compress cheeks comment may have a little with the angle of the windscreen added on. Just a little. Other then that it's just about a perfect setup for what it is designed to do. And just to clear up any doubt when I was at the gas station and whereever else I ride, I have never ridden around with a forsale sign nor have i ever actually ever had a sign on one. But when someone comes up to you and says that, about the only other comment that ranks close to me is when someone says "man I used to own a bike just like that" and they have that momentary flash back in their eyes you feel like their existence hinges on your next breath.
Last edit: 26 Jan 2019 10:36 by Olajoe.
- 650Dude
- Banned
26 Jan 2019 10:44Olajoe wrote: Sounds bueno. And the fact that it does not interfere with the filter super super nice. Don't know about you guys but around here in the rockies these bikes/non oem exhaust w/baffle will stop other motorist in their tracks. Many times someone in front me even a guy on highly modified sports bike with the sawed off go-to-jail loud pipe stop to listen to my bike go by this is while the traffic light is green. Take the baffle out, and it's game over. Oh, in my previous reply is not to put the bikes hp up on a stage. Just to suggest that in stock configuration kawasaki just about nailed.. The compress cheeks comment may have a little with the angle of the windscreen added on. Just a little. Other then that it's just about a perfect setup for what it is designed to do. And just to clear up any doubt when I was at the gas station and whereever else I ride, I have never ridden around with a forsale sign nor have i ever actually ever had a sign on one. But when someone comes up to you and says that, about the only other comment that ranks close to me is when someone says "man I used to own a bike just like that" and they have that momentary flash back in their eyes you feel like their existence hinges on your next breath.
I dont dare take the baffle out. hahaha. Im sure it would be way too loud, and I would then have to rejet the carbs.
- old_kaw
26 Jan 2019 10:53 - 26 Jan 2019 10:55Olajoe wrote:old_kaw wrote: I got it installed today, Perry. There goes my stealth bike.. I seemed to pick up an "escort" within half a mile from home while on my maiden voyage. No more coming home quietly. It does have a deep "knarly / throaty " sound, turning my mild mannered, docile bike into the monster it always has been. (it was lurking under that quiet, muffled persona.)
I'd have to agree on the jetting. No spitting or sputtering, ever. It pulls HARD all of the time. It absolutely lays waste to everything on the highway. I kept the stock gearing when I changed the chain and sprockets last year(15/39) and as Steve Wood would say.. it is a little "zingy", but it's ok. I also agree that fattening it up a tad would cool it off a little, but "lean is mean" .. until you burn something up.
It's hibernating.
Not splitting hairs here, but it's 38 years old, and still a monster. lol
Last edit: 26 Jan 2019 10:55 by old_kaw.
The following user(s) said Thank You: Olajoe
- 650Dude
- Banned
26 Jan 2019 11:14 - 26 Jan 2019 11:15Not splitting hairs here, but it's 38 years old, and still a monster. lol
I killed one of these bikes racing on my CB900F pictured below. I left the Z1000 in the DUST!
I know the z1000 is a monster but the CB900F ... just wow.
Last edit: 26 Jan 2019 11:15 by 650Dude.
- old_kaw
26 Jan 2019 11:22good for you.
yawn.
The following user(s) said Thank You: SWest, Warren3200gt
- 650Dude
- Banned
26 Jan 2019 11:26 - 26 Jan 2019 11:45old_kaw wrote:650Dude wrote:Not splitting hairs here, but it's 38 years old, and still a monster. lol
good for you.
yawn.
CB900F >>>>> KZ1000
Last edit: 26 Jan 2019 11:45 by 650Dude.
26 Jan 2019 12:37
I pour milk on Hondas and eat them for breakfast
:evil: :evil: :evil: :evil: :evil: :evil:
LOL Couldnt resist.
Only thing funnier is a guy who buys a HD Sportster and puts pipes on it and the bike is now the fastest motorcycle in the world and can beat all comers... LOL
Street Fighter LTD
LOL Couldnt resist.
Street Fighter LTD
