Valve Cover Gasket Tips ?
- mrmach5
16 Dec 2017 05:45
In an effort to pretty up my 77 KZ650B, I purchased a used valve cover off e-bay and sent it off to a Chromer. when it gets back and I remove my perfectly good non-leaking stock cover, and tips on the swap? Who's gasket is best ? Sealant , no sealant? Dry, lightly greased? Will I disrupt the end plugs when the cover comes off?
Thanks in advance for any info.
Re: Valve Cover Gasket Tips ?
16 Dec 2017 06:22
OEM gasket is my preference.
RTV on the curved portion of the half moons as needed.
A light coating of oil or grease on the side of the gasket that contacts the head is my preference as well.
16 Dec 2017 06:47
I used oil this last time. Been using RTV on the plugs for years but sound up with weeping. This time I used Yamabond and they're dry as a bone.
- mrmach5
16 Dec 2017 07:11
With regards to YamaBond. I notice there is a #4 Semi Drying and a #5 Drying. Which is the preferred?
16 Dec 2017 07:37
#4
16 Dec 2017 08:11
www.amazon.com/Three-Bond-Liquid-Gasket-1184A100G/dp/B007TWXI1K
Or go down to your local autoparts store and get this...for $5. Be sure to clean the half moon and engine surface with acetone/brake cleaner/alcohol first, before bonding.
- RonKZ650
16 Dec 2017 19:05
Use the Yamabond #4 or threebond, but only on the curved area of the end plugs and along the top of the end plugs slightly onto the aluminum. Don't fool with the end plugs if they are not leaking. If they are leaking, don't try to fix leaks via gasket sealer. Replace the plugs. Original Kawasaki gasket best bet. My opinion after a couple times replacing end plugs/gasket.
16 Dec 2017 20:32 - 16 Dec 2017 20:32
+1
My experience has been the same as RonKZ650's. Ed
Last edit: 16 Dec 2017 20:32 by 650ed.
- zukdave
17 Dec 2017 04:29
I've never understood the whole putting oil or grease on a gasket ment to stop oil leaks deal.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
17 Dec 2017 05:05 - 17 Dec 2017 05:52
A quality valve cover gasket like the OEM type will survive several removals for valve adjustment AS LONG AS IT DOESN'T STICK AND TEAR. That's the reason for the oil/grease on the head contact surface side of the gasket. It won't affect how the gasket seals and will assure it can be used more than once.
Last edit: 17 Dec 2017 05:52 by Nessism.
- Old Man Rock
17 Dec 2017 06:25
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- asphalt900
17 Dec 2017 08:26
This is what I do to the Z1 Cam Covers. Your process would be the same. A bit of overkill maybe but it works Every time, No brown stains around sealing area. Re-torque required after the perimeter o-ring seats-in. Benefit of this? It provides a raised "pinch point" that the flat gasket cannot offer and it's a clean assembly. I also use the same technique for "most" of the carbs (VM, TK float bowls) I rebuild. Again, no brown staining around bowl to casting, Ever. Both applications the o-ring sticks to the applied surface so the item can be removed and remounted without a problem. Hope it helps
