Valve Cover Gasket Tips ?
  • gordone
  • gordone's Avatar
Re: Valve Cover Gasket Tips ?
18 Dec 2017 08:39 - 18 Dec 2017 08:46
#776300
What about the base gasket, don`t use anything?
Project:
Last edit: 18 Dec 2017 08:46 by gordone.
  • asphalt900
  • asphalt900's Avatar
  • Away
18 Dec 2017 13:06
#776309
I keep the original gasket in place. Potential for the lobes of the cam/cams to hit if not in place. Head to bottom of gasket "I" use Loctite 518. Half-Moons Yamabond. I always set the camshaft end plugs first, using a donor cam cover and let set overnight. Loctite 518 is actually a flange sealant, also use it for engine cases.
