Cylinder wall condition.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
Re: Cylinder wall condition.
10 Dec 2017 09:41
#775795
I seem to recall partzilla having them as well. For more dinero, of course.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • gordone
  • gordone's Avatar Topic Author
10 Dec 2017 10:21
#775797
I hope the imd piston work well, I found them expensive enough :)
Have you found +0.5mm piston on Partzilla now also ?
Project:
  • Kray-Z
  • Kray-Z's Avatar
  • I need more power Scotty....
10 Dec 2017 22:28
#775821
As you already suspect / know, the only way you should re-use a cylinder is if there is no visible damage or wear beyond the recommended service limits, If your cylinders show a line of pitting (like the pictures) or deep scoring on the cylinders or piston skirts, a simple "de-glazing" hone and a set of new rings typically isn't enough. The cylinders will require re-boring and oversize pistons and rings installed. The 0.4 mm clean up bore (test) is a good idea before buying a 0.50 mm over piston kit....those pits look pretty deep to me....the 0.50 pistons mean only 0.25 mm is cut / honed from the sleeve wall, and that might not be enough.....
Daftrusty (KZR member) used a set of those Cruzin Image pistons in his 750 and they seemed to work well for him....
  • gordone
12 Dec 2017 06:46 - 12 Dec 2017 07:01
#775887
I delivered the block to a local engine specialist, he think +0,25mm piston is enough, but to be sure he will take of metal step by step to figure it out....
My questions is, I have been given link to imdpistons who are +0,5mm, is it possible to get +0,25mm?
I guess no, since nobody have talked about that earlier here?
I have crated a separate thread for the big bore:
www.kzrider.com/forum/2-engine/607514-up...e-to-bigbore-pistons
Project:
Last edit: 12 Dec 2017 07:01 by gordone.
  • Kray-Z
  • Kray-Z's Avatar
12 Dec 2017 10:31 - 12 Dec 2017 10:33
#775903
No, most ADDED - AFTERMARKET oversize pistons for Japanese bikes come in only two overbore sizes, at best. So only 0.5 mm and 1.0 mm over stock are typically available. Don't confuse "oversize" with "big bore" pistons - oversize are meant to repair slight damage and return stock performance (most of the time). Big bore is usually associated with increasing performance / power.
Last edit: 12 Dec 2017 10:33 by Kray-Z.
  • gordone
13 Dec 2017 07:39
#775962
I think have descied to go for overize +0.5mm pistons.... combination of norwegian regulation and possibility of coming into new problems with my bike... I want to run nice for the summer :) and I`m happy with exssitign power for now...
I have started a fresh threat about finding the best option of pistons, when it comes to +0.5mm pistons.
kzrider.com/forum/2-engine/607519-750cc-oversize-piston-0-5mm
Project:
  • gordone
15 Dec 2017 14:35
#776094
When I talked with the engine workshop earlier these week, he had a theory engine has been standing for a while at some point, and it had started to corrod (corrosion) in the cylinder, and when you start up you have kind of dust combine with the heat... Could be the reason for these damage.
Project:
  • SWest
  • SWest's Avatar
  • 10 22 2014
15 Dec 2017 16:39
#776097
Condensation.
  • gordone
16 Dec 2017 03:47
#776122
I have ordered the big bore kit now... hehe :) Hope I don`t have done something stupid, I don`t want a test bike for races... I want a bike a I can trust :)
kzrider.com/forum/2-engine/607514-upgrad...tons?start=20#776121
Project:
