MTC-G1135-3 Piston Kit
- daveo
14 Jul 2017 10:52
Thinking about it (under my stock 84 bathtub head and ZX cams), with no changes to the bottom-end. :whistle:
www.mtceng.com/mtcproducts/products/pistons/kawasaki/gpz1100
Requesting member advice.
1982 KZ1100-A2/1170 sleeper 😀
Re: MTC-G1135-3 Piston Kit
14 Jul 2017 11:03
Check Pricing thru Joe at Pitstop ./ He works closely with MTC and usually has the best prices
Regardless as to what some have said about Joe , I have had all good dealings with him.
- KZB2 650
14 Jul 2017 14:09
Got me think in about it too and it sounds like a blast. Am looking forward to seeing what kind of power increase Joe tells you you might expect......... guessing with the cams, head, carbs, cc's and improved comp it will be a real kick.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- daveo
14 Jul 2017 16:36
Will the old bottom-end be able to handle the stress and pressure increases? She is a stress monger, but
14 Jul 2017 16:45daveo wrote: Will the old bottom-end be able to handle the stress and pressure increases? She is a stress monger, but
Hi Dave
Unless you have a existing problem with the bottom end you should be fine. If racing is intended you may want to weld the crank.
If you want another qualified opinion , e mail or call Les Holt or Joe at Pitstop
The following user(s) said Thank You: GPz550D1, daveo
14 Jul 2017 16:49 - 14 Jul 2017 16:55
Need some APE studs and cylinder head nuts, crank welding and center main bearing plate.
I did bore my crank case 15 year ago for 1197 cc sleeves in case i go this way.
Last edit: 14 Jul 2017 16:55 by Scirocco.
- daveo
14 Jul 2017 17:44Scirocco wrote: Need some APE studs and cylinder head nuts, crank welding and center main bearing plate.
Got the top-end covered, but the bottom is likely to remain bone-stock. :whistle:
- Kray-Z
- I need more power Scotty....
19 Jul 2017 19:08
Dave,
I think the only weakness to be concerned with is the stock crankshaft. I've had two 81 cranks twist (but only 81's) and a few bathtub head GPz cranks that chewed up number 5 main bearing when the thrust bearing (actually just a cheap thrust washer) next to it self destructed and the hard steel shrapnel then washed through the bearing. That is why my search continues for a good useable GPz 18 mm small end crank...I've got two with ruined no. 5 bearing journals already.
I recommend getting your crank disassembled, checked, replace the thrust washer with a Torrington needle roller bearing, re-assembled, indexed, straightened, and welded. It costs about $500-700, but in my mind it is worth it. If a main or rod bearing goes, or the crank twists, it will cost much more than that to fix...
-Scott
-Scott
- daveo
19 Jul 2017 23:11 - 19 Jul 2017 23:15
Not sure I'll be doing much more with this bike, than potentially selling it. Then I would get cranky for sure. :lol:
In a week or so will know if my toy box belongs to someone else. At that point I will have only a single-stall garage to put my bike along with a bunch of woodworking machines and tools in, including her 98 Blazer which barely fits.
I hope to sell my collection of work-related stuff by the end of August...and do a couple jobs at the same time...possible, but not likely.
Several big life changes may well be in-coming...
Last edit: 19 Jul 2017 23:15 by daveo.
20 Jul 2017 06:09
as long as you you don't plan to be doing hard launches with sticky tires you shouldn't have any trouble out of a stock crank with the 10.5-1 kit.
imho,
imho,
The following user(s) said Thank You: GPz550D1, daveo, Street Fighter LTD
- daveo
20 Jul 2017 08:58
Is there a fortification option for the crank without having to split the case, with the engine still in the frame?
21 Jul 2017 06:06
the only way to strengthen the crank is to weld it.
so therefore the answer is "NO".
sorry
sorry
