- Thank you received: 2
KZ 750 B Twin Cylinder jug stuck, can not rmove...
- woodman260
25 Jun 2017 15:38 #765369
by woodman260
KZ 750 B Twin Cylinder jug stuck, can not rmove... was created by woodman260
I have a 1978 KZ 750 twin that I am trying to remove the cylinder jugs. It does not want to budge. It appears that one of the bolts that hold it in place has been rusting for the past 39 years and has rust welded the jugs in place. I am trying to pry it up at the pry points but no dice. I do not want to wreck the aluminum. Has anyone had problems with this and might have a solution? Thanks
- Thank you received: 2829
25 Jun 2017 18:46 - 25 Jun 2017 18:47 #765380
by 650ed
Replied by 650ed on topic KZ 750 B Twin Cylinder jug stuck, can not rmove...
Are you positive you removed all the cylinder head nuts and bolts? According to the manual there are 11 of them. Ed
Last edit: 25 Jun 2017 18:47 by 650ed.
The following user(s) said Thank You: woodman260
- woodman260
26 Jun 2017 09:51 #765420
by woodman260
Replied by woodman260 on topic KZ 750 B Twin Cylinder jug stuck, can not rmove...
The Head is off, all the nuts and bolts are removed. I think the problem is the bolts sticking up through the block are rusted and locked the block in place. I think it might be one or two. I heard this is common with these engines because water can get down the shaft and cause the bolt to rust, locking it in place. I put some CLP Breakfree military rifle cleaner down the shafts for 24 hrs but not sure if it is working. Maybe a better product for disolving rust?
- Thank you received: 2063
26 Jun 2017 10:16 #765421
by Street Fighter LTD
Replied by Street Fighter LTD on topic KZ 750 B Twin Cylinder jug stuck, can not rmove...
Do the crank and pistons move ?
- woodman260
26 Jun 2017 10:42 #765423
by woodman260
Yes, the pistons move up and down freely.
- Thank you received: 2234
26 Jun 2017 13:04 #765431
by TexasKZ
Replied by TexasKZ on topic KZ 750 B Twin Cylinder jug stuck, can not rmove...
For breaking loose rusted fasteners, Cano Kroil, or a mixture of equal parts ATF and acetone seem to be best. Daily applications for several days may be needed.
- woodman260
26 Jun 2017 13:31 #765432
by woodman260
ATF?
26 Jun 2017 13:58 - 26 Jun 2017 14:05 #765433
by Scirocco
Replied by Scirocco on topic KZ 750 B Twin Cylinder jug stuck, can not rmove...
Automatic Transmission Fluid
ATF and acetone 50/50 mix is also called Magic Mechanic Fluid (MMF)
A self made rust dissolver
BTW
Have you remove this bolt nut
BTW
Last edit: 26 Jun 2017 14:05 by Scirocco.
The following user(s) said Thank You: GPz550D1, woodman260
- woodman260
26 Jun 2017 14:41 #765438
by woodman260
Yeah, I removed that nut as well......sigh.
26 Jun 2017 14:49 #765441
Once you exhaust options of using rust dissolving fluids , if still remains stuck 2 options are ..
2x4 against block and strike with dead blow hammer. ( spreads load and point of impact to a number of fins ) work back and forth with blows to opposite sides of block
and get a stud pulling tool and try and twist the offending stud to break the bond
26 Jun 2017 14:53 #765443
by Scirocco
Okay, you can try to turn the cylinder blots out a little bit to loosen the rust by countering two nuts on it.
- Thank you received: 2749
26 Jun 2017 15:14 #765446
by SWest
Replied by SWest on topic KZ 750 B Twin Cylinder jug stuck, can not rmove...
I used the ATF/acetone mixture and heat on broken bolts. Once I heated them up I could see bubbling and poured more on it. After a few tries they came right out. I was about to suggest the 2X4 method but Dave beat me to it.
