KZ 750 B Twin Cylinder jug stuck, can not rmove...
- woodman260
Re: KZ 750 B Twin Cylinder jug stuck, can not rmove...
26 Jun 2017 18:11 - 26 Jun 2017 18:12
will give that a try on Wednesday night, Thanks Guys. Will let you know how it goes.
Last edit: 26 Jun 2017 18:12 by woodman260.
- Tyrell Corp
27 Jun 2017 03:58
Had this one before on a 550/4, what I did was use a couple of 1 inch lengths of plastic pipe, put them in outer pots, replaced cy;nder head and fixed with the m6 bolts at the front and rear of the cylinder head to attatch the head to the block (jugs), Obviously you don't put nuts on the studs, just the three m6 head/block fasteners.
Then get a long 'gypsy bar' and socket to turn the crank thus forcing the block off. Ths used with penetrating oil and tapping it with a rubber mallet -careful fins break of easily. Perhaps fill it with deisel for a few days.
