Is this all i need to get 140hp
  • obie83
  • obie83's Avatar Topic Author
10 Jun 2017 22:40
#764041
been doing some research about more hp. At first i thought about a zrx1200r engine swap but i think it might be cheaper to follow this route i found on the oldkawman website.. oldkawman hp my question is this. Is this information reliable and if not what would you recomend to get the 140hp range. bike is a 80 kz1000 and would be a street bike
  • TexasKZ
  • TexasKZ's Avatar
Re: Is this all i need to get 140hp
11 Jun 2017 06:47 - 11 Jun 2017 06:51
#764059
That looks like pretty solid advice, but his prices are really old.
kzzone.com/
If you get serious about building an engine, I strongly recommend contacting a reputable builder like Cavenaugh, APE, etc., and follow their recommendations to a T.
Last edit: 11 Jun 2017 06:51 by TexasKZ.
The following user(s) said Thank You: obie83
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
11 Jun 2017 08:14
#764078
TexasKZ wrote: That looks like pretty solid advice, but his prices are really old.
kzzone.com/
Or drive over to Indiana and visit Les Holt at PDM.
He can build you a motor with as much power as you want
Dave B) B) B)
  • obie83
11 Jun 2017 21:48
#764138
You guys think the 1075 kit would do this. Or is there something better.
  • zed1015
  • zed1015's Avatar
11 Jun 2017 23:19
#764140
Gonna need a fresh ground up built up motor with welded crank, 1075 wiseco's, ported head, bigger valves, fast road cams, bigger carbs, fresh HD camchain , manual tensioner and probably new idlers, dyna ignition, dyna coils and a decent 4-1 pipe.
Gonna cost more than a ZRX motor especially if you pay a shop for the work but with the motor swap it wouldn't be a real Z anymore.
12 Jun 2017 05:54
#764145
It isn't going to be inexpensive, that's for sure. What does your bike budget look like? Ed
  • Moderator
  • Moderator
12 Jun 2017 07:48
#764152
Upping the power comes in 5000.00 Dollar increments.
First 5 for hot street bike,
10 Grand buys you a Real Bad ass Hot Rod
15 Grand TURBO ready to go
Ask me how I know ..............
Dave B) B) B)
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 Jun 2017 07:58
#764153
I'm having trouble keeping a rear tire on mine now. 140? I'd be changing tires every month.:woohoo:
  • obie83
12 Jun 2017 13:16
#764168
My engine budget is about 2500 to 3k right now. I was thinking I would just but the wiseco kit and that be it. Guess I was wrong, what cam specs and carb size do you guys recommend.
  • obie83
12 Jun 2017 13:17
#764169
Do you know about how much up you have right now. Is it a daily driver
  • obie83
12 Jun 2017 13:18
#764170
Would that be a tough motor swap. They kinda look the same to me
  • TexasKZ
  • TexasKZ's Avatar
12 Jun 2017 17:41
#764181
obie83 wrote: Would that be a tough motor swap. They kinda look the same to me
If you are asking about a ZRX swap, it has been done, but it is far from a bolt in job. For instance, you will need to fabricate new motor mounts, a custom exhaust system, brackets for the radiator and the overflow tank, as well as for the oil cooler. You will have to install the ZRX clutch lever and master cylinder assembly since the clutch is hydraulically actuated. There will be chain alignment issues and your tachometer will no longer work. You will also have to wire in the ZRX ignition system and regulator/rectifier. You will have to convert to individual pod filters that are small enough to clear the frame, the rejet the carbs. Et cetera.
