Is my stator knackered?
- seanile
- let's try this one more time with feeling.
i can grab a better picture tomorrow if need be. but the amount of lacquer type material that looks to have bubbled doesn't seem right...
cheers,
sean
1982 Kawasaki KZ1000K LTD
2014 Yamaha Bolt XVS950
- Thank you received: 2740
- daveo
- Thank you received: 654
SWest wrote: It does look like it got hot. pic of the inside of the rotor?
Doesn't necessarily mean it is bad though. I had my stator tested at an auto-electric service business, where they rebuild starters and alternators for cars...while I waited at the counter! Cost me a few bucks, only because I insisted on paying the guy.
Those folks are good people to know.
1982 KZ1100-A2
- seanile
- seanile
- Thank you received: 2829
- KZJOE900
- Admin
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- Thank you received: 2812
- Thank you received: 2059
Stator is dark colored over the years by the head of the oil but the isolation of the copper wire looks like not cracked or shorted internal.
Did it smell burnt or better did you do shortcut test with a multimeter ( Beep the 3 wires current passage each other )???
Michael
- zed1015
- Thank you received: 1551
Colour is from hot oil staining.
Just check the output with a multimeter and leave alone if you get the same or very similar readings within the service parameters from each phase.
Obviously if one phase is significantly low or zero then repair or replace the windings.
On my 750E I had two different used stators that met the specs in the manual, yet the output was weak. Both had about .8 ohm of resistance across all the various paths, and both also showed no load voltages of about 75 VAC. Despite this the charging system voltage couldn't get over 13.7 VDC. I tried several different R/R's and made sure the wiring was fresh but still no love. Bit the bullet and bought a new Ricks stator and charging system voltage immediately went to 14.5 VDC. Interestingly, the Rick's stator had more resistance across the windings than the clapped out OEM stators - about .85 ohms.
Bottom line is that the service manual specs do not gurantee the stator is good. The proof is in the pudding when the stator is under load.
