Is my stator knackered?
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: Is my stator knackered?
28 Apr 2017 20:11
#760562
Tell us the problem and you get a solution here- usually.
undercharging, overcharging, fuses blowing, heat, vibration, noise ?
www.kzrider.com/forum/4-electrical/59810...r1-charging-problems
Do a resistance check between the tails of the yellow alternator wires, checking between each and any pair of the three and ground, less then 1 ohm on the yellow tails and infinity to ground.
Trying to guess this without a meter is pissing in the wind.
The following user(s) said Thank You: seanile
