KZ1000 Cam Timing - Strange Alignment Issues
- FrankenKZ650
04 Dec 2016 12:40
Hi All,
I am totally confused by my cam timing (1977 KZ1000 - totally stock engine). It looks like it is 1/2 of a tooth off when the "T" mark is lined up. I've attached some pics. The carrot mark on the exhaust looks a touch too high, and the intake cam looks a bit too low when looking at the lobes together. If I moved both cams one tooth, I think it would be too much. The 28 mark lines up.
The bike runs pretty good, but there is a slightly buzzy feel to it in the pegs. It will pull to 100+ without too much trouble. This has me stumped.
1977 KZ650 (1982 KZ750-4 Engine)
Vance & Hines 4:1
K&N Pods
1977 KZ1000
Kerker 4:1
K&N Pods
Vance & Hines 4:1
K&N Pods
1977 KZ1000
Kerker 4:1
K&N Pods
Re: KZ1000 Cam Timing - Strange Alignment Issues
04 Dec 2016 12:53
There are three identical posts here. Do you want to delete two?
- FrankenKZ650
04 Dec 2016 13:02
Yes, sorry. My phone kept saying error, so I didn't think it went through.
Vance & Hines 4:1
K&N Pods
1977 KZ1000
Kerker 4:1
K&N Pods
Vance & Hines 4:1
K&N Pods
1977 KZ1000
Kerker 4:1
K&N Pods
04 Dec 2016 14:07
Happened to me too. Done.
The following user(s) said Thank You: FrankenKZ650
04 Dec 2016 14:11
The little > needs to be level or just below the edge of the head. Starting with the next pin count 28.
- missionkz
04 Dec 2016 14:33
Looks pretty close to right to me. The photo angle is a bit deceptive though.
If the 28th cam pin mark on the intake sprocket lines up with 28 pins of the chain from the carrot, I think it is OK.
Mileage?
The cam chain and sprockets could be slightly worn enough to be that little bit off....
Mileage?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- FrankenKZ650
05 Dec 2016 04:37swest wrote: The little > needs to be level or just below the edge of the head. Starting with the next pin count 28.
Thanks, Steve. It is close to level, but just seems to high compared to the pics in the manual. If I were to go one tooth down it looks like it will be far under the surface of the head. I have a closer pic with the arrow highlighted on my computer I'll post tonight.
Thanks again!
Vance & Hines 4:1
K&N Pods
1977 KZ1000
Kerker 4:1
K&N Pods
Vance & Hines 4:1
K&N Pods
1977 KZ1000
Kerker 4:1
K&N Pods
- FrankenKZ650
05 Dec 2016 04:42missionkz wrote: Looks pretty close to right to me. The photo angle is a bit deceptive though.
Mileage?
Thanks Bruce. The bike has 35,000mi on it. I'll post a better pic that is on my computer tonight.
I've heard that some kz1000 cranks have different sprockets depending on year. I wonder if the bike could have had a different crank put in at one time? Not sure if that is even a possibility. The engine runs pretty good, but I've been chasing down a slight buzz since I've had it.
Thanks!
Vance & Hines 4:1
K&N Pods
1977 KZ1000
Kerker 4:1
K&N Pods
Vance & Hines 4:1
K&N Pods
1977 KZ1000
Kerker 4:1
K&N Pods
05 Dec 2016 05:07
If you had a crank with the wrong number of teeth, you would know very shortly after it was installed, as after a couple of revolutions the valves would have been smashing into the pistons. :pinch:
05 Dec 2016 05:48
I set my arrow just below the surface. 35000 miles is just broken in.
- FrankenKZ650
05 Dec 2016 15:36swest wrote: I set my arrow just below the surface. 35000 miles is just broken in.
Hello,
I've attached a close-up of the cam mark. I added an arrow over the arrow mark on the cam. To me, it looks like if I go 1 tooth down, the mark would be way below the surface of the head.
What do you all think?
Thanks!
Vance & Hines 4:1
K&N Pods
1977 KZ1000
Kerker 4:1
K&N Pods
Vance & Hines 4:1
K&N Pods
1977 KZ1000
Kerker 4:1
K&N Pods
05 Dec 2016 16:13
Ship it. :woohoo:
