GPZ/KZ 750 Oil seal cover
- 750 R1
02 Nov 2016 18:40 - 02 Nov 2016 18:44
Hi Guys, I'm chasing the alloy oil seal cover, the one under the sprocket cover that the oil seals fit into, Mine is cracked and the top chain / clutch rod guard bolt mount is broken off, searched everywhere locally and can't find one, any help would be much appreciated....
Bike is in the title, its a GPZ750R1...
Its part 14025A on Partzilla's parts fiche
www.partzilla.com/parts/search/Kawasaki/...NE+COVERS/parts.html
Last edit: 02 Nov 2016 18:44 by 750 R1.
Re: GPZ/KZ 750 Oil seal cover
02 Nov 2016 19:28 - 02 Nov 2016 19:39
Why don't you try the Parts Wanted forum? or ebay?
That part fits scades of different bikes. Shouldn't be hard to find. Be aware that a lot of used ones have broken bolts in them. It's not difficult to remove the broken bits but it helps if you are experienced in doing so otherwise get one without any.
1980 KZ550-A1 BREATHER COVER-OIL PAN ('82-'83 A3-A4)
1980 KZ550-C1 LTD BREATHER COVER-OIL PAN ('82-'83 C3-C4)
1980 KZ750-H1 LTD ENGINE COVERS (KZ750-H4)
1981 KZ550-A2 BREATHER COVER-OIL PAN ('82-'83 A3-A4)
1981 KZ550-C2 LTD BREATHER COVER-OIL PAN ('82-'83 C3-C4)
1981 KZ650-H1 CSR ENGINE COVERS ('83 H3)
1981 KZ750-H2 LTD ENGINE COVERS (KZ750-H4)
1982 KZ550-A3 BREATHER COVER-OIL PAN ('82-'83 A3-A4)
1982 KZ550-C3 LTD BREATHER COVER-OIL PAN ('82-'83 C3-C4)
1982 KZ550-H1 GPz BREATHER COVER-OIL PAN
1982 KZ650-H2 CSR ENGINE COVERS ('83 H3)
1982 KZ750-H3 LTD ENGINE COVERS (KZ750-H4)
1982 KZ750-R1 GPz ENGINE COVERS
1983 KZ550-A4 BREATHER COVER-OIL PAN ('82-'83 A3-A4)
1983 KZ550-C4 LTD BREATHER COVER-OIL PAN ('82-'83 C3-C4)
1983 KZ550-H2 GPz BREATHER COVER-OIL PAN
1983 KZ650-H3 CSR ENGINE COVERS ('83 H3)
1983 KZ750-H4 LTD ENGINE COVERS (KZ750-H4)
1983 KZ750-L3 ENGINE COVERS
1984 KZ700-A1 ENGINE COVERS
Last edit: 02 Nov 2016 19:39 by Nessism.
- 750 R1
02 Nov 2016 22:22
We didn't get a lot of those models in Australia, I've been to a few shops and rung a few parts places but no one has anything, The part is obsolete through Kawasaki..I may have to get creative with some devcon. I've put this topic in the wanted section...
- 750 R1
02 Nov 2016 23:11 - 02 Nov 2016 23:13
No eBay APP ID and/or Cert ID defined in Kunena configurationA lot of those covers you listed have different bolt patterns for the chain guide, do the chain guides differ or are the covers different too....?
Last edit: 02 Nov 2016 23:13 by 750 R1.
The following user(s) said Thank You: dvnsta
03 Nov 2016 04:47
No eBay APP ID and/or Cert ID defined in Kunena configurationThe chain guide is a bolt on part. Check this one...
- 750 R1
03 Nov 2016 14:17
I know its a bolt on part, thats what has broken my cover, some previous genius over tightened the bolts and snapped the top off and split the cover.... My point was that in those links you posted they had different bolt patterns for the chain guard.
Nessism wrote: The chain guide is a bolt on part. Check this one...
03 Nov 2016 14:36 - 03 Nov 2016 14:37
I only provided one link. Did you look at it? I think it's the proper cover. The cover on my 750 was broken so I searched ebay until I found the right one and then I bought it. I had to extract two broken bolts but that was no big deal.
The list of bikes I provided previously came from the parts fishe at Partzilla. I can't say for sure if this information is right or wrong though.
Here is a photo of my 750 showing the cover. I believe your R1 used the same cover as a bunch of different bikes. Main difference is the chain guard piece and how it fits on the cover.
750 R1 wrote:Nessism wrote: The chain guide is a bolt on part. Check this one...
Last edit: 03 Nov 2016 14:37 by Nessism.
- 750 R1
03 Nov 2016 15:37 - 03 Nov 2016 15:42
I'm not sure what happened or I saw your post as you posted it, but that link wasn't there when I replied...? The links I mentioned earlier were the ones from Partzilla, some were definitely not the same, the one in the Ebay link looks correct but it says "Does not ship to Australia"...!!! ... I would grab that if he'd ship to Aus.... what a bummer... I tried to message the seller but can't even do that..!! Any Florida members that could possibly grab that and ship for me...?
Last edit: 03 Nov 2016 15:42 by 750 R1.
03 Nov 2016 15:42
Link?
- 750 R1
03 Nov 2016 15:43
swest wrote: Link?
03 Nov 2016 15:51 - 03 Nov 2016 15:51
Is the one you found local? That chain guard looks cheezy. What does yours look like?
Last edit: 03 Nov 2016 15:51 by SWest.
- 750 R1
03 Nov 2016 15:58 - 03 Nov 2016 16:03swest wrote: Is the one you found local? That chain guard looks cheezy. What does yours look like?
I'm not sure what you mean Steve, I haven't found anything local, Nessism gave me that link and another member said he will be pulling one off a spare engine some time in the future, but if I could get someone stateside to help me purchase the one in the link, i would grab it now, It would save me patching up the damaged one I have, its the only one for sale I've managed to see thats exactly the same as mine. Yes, the chain guard is flimsy but that's how they came from the factory...
Last edit: 03 Nov 2016 16:03 by 750 R1.
