Open cam chain for 1982 GPZ750?
  • rrsmsw9999
  • rrsmsw9999's Avatar
Re: Open cam chain for 1982 GPZ750?
31 Oct 2016 18:01
#746765
How do fish the replacement chain around the crank? Assume u use the existing one and carefully fish it. Also is the existing one broke or what?. R
1980 KZ 1000E2
Crashed 6/2016
1980 KZ550A
Sold 3/2016
  • Madtrout
  • Madtrout's Avatar Topic Author
01 Nov 2016 04:47 - 01 Nov 2016 04:48
#746809
The existing chain is not broken, it merely has 97,000 miles on it. To install the new chain you have to cut the old one and attach the new one to it with a master link, then turn the engine while maintaining tension on both ends to keep it from coming off of the sprockets. When the new one is through, you disconnect the master link to the old chain and rivet the two ends together.
Last edit: 01 Nov 2016 04:48 by Madtrout.
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Nov 2016 06:57
#746819
The peen over master links are made so they can done that way. The one I got so long ago was an endless bronze HP chain I got from Hollywood Kawasaki. The plates were a little wider so it rode on the plastic on the sides of the sprockets. Didn't cause any problems but I was uncomfortable with it all that time. .They also sold me a points setup with GM points and a cool timing light built in and it had a micro switch. It worked if you were in a dark room. :pinch: They also sold me a duel roller chain setup with a purdy blue anodized rear sprocket. :side: Both were a waste of money but being young I liked cool stuff. Still have the points setup laying in the dirt and the chain was prone to having the pins work their way out. :blink: Cool isn't always better. :whistle:
  • KZB2 650
  • KZB2 650's Avatar
01 Nov 2016 07:23
#746822
Since I didn't split the case a while back I would have had to peen one on too. Z1 talked me out of it since I only had 29,000 miles and would be running a mild 750 cam along with 80lbs on the Ape springs vs 90. They told me the softer link that you needed was then the weak spot but if done right the odds say it would a been ok. I chickened out since it would have been my first peen job but later wished I would a run the motor to Red Line to have had them peen it.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
  • aek
  • aek's Avatar
08 Nov 2016 22:31
#747611
This is a little slow but I recently purchased a hyvo type cam chain for my 1980 KZ750 with a open rivet link from Raw Power Motorcycles in the United Kingdom. I t comes endless so it can be installed that way or cut and installed with the rivet link. The chain is manufactured by Borg Warner in Japan and cost 75.00 shipped. Service was very good. So far I haven't installed it. it doesn't look like a very easy job doing it in place.
Hope this is helpful.
art
1980 750-4 LTD original owner
The following user(s) said Thank You: Madtrout
  • undiablo
  • undiablo's Avatar
09 Nov 2016 04:22 - 09 Nov 2016 04:26
#747616
Attachment IMAG0034.jpg not found
Attachment IMAG0038.jpg not found
Attachment IMAG0030.jpg not found
This a is from another Forum, ADV Rider. He could practice rivetting the chain because he bought a 152 links cam chain instead of a 150 links. Once he was comfort on rivetting, he cut the unnecesary links and rivetted with a master link from K&L. 5000 miles since then, everything OK.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
Last edit: 09 Nov 2016 04:26 by undiablo.
The following user(s) said Thank You: JR
  • Madtrout
09 Nov 2016 05:02
#747618
Thanks for the replies. I ordered a cam chain from RawPower out of the UK, but it came in with the wrong master link, so I returned it. I guess I'll reorder from Z1enterprises. Still looking for the right tool to rivet the solid nosed master link. I wonder if anyone makes a miniature quad stake attachment for my BIkemaster rivet kit. Mark
  • Madtrout
16 Nov 2016 13:23
#748091
Well I took the plunge and bought a new cam chain and open rivet from Z1Enterprises. The install went very smoothly. I bolted a piece of wood to the head that gave me a nice working space. I blocked in a small anvil that was used as the backing for the peening operation.
A small ball peen hammer was used to flare the head of the rivet pins. I carefully avoided hitting the side plate. The link moved freely and after 200 miles with many revs up to 8500rpm I am feeling rather good about the state of the repair. The bike, with 95,000 miles is running better than ever. Thanks again for all of your advice. Great forum, Mark
  • Madtrout
29 Nov 2018 08:59
#794347
Well here is the two year update. 15,000 miles later and the cam chain has performed flawlessly. As Lou Reed said in New Sensations, "I love that GPz so much I could kiss her!"
The following user(s) said Thank You: undiablo
  • undiablo
  • undiablo's Avatar
29 Nov 2018 12:23
#794357
Glad to hear that. Did you take any pics for instance?
  • Madtrout
29 Nov 2018 12:24
#794358
Sadly no
  • undiablo
  • undiablo's Avatar
30 Nov 2018 04:09
#794390
OK. Did grind off the cam chain to install the master link? Which tool did you use to rivet the pins?
