Open cam chain for 1982 GPZ750?
- Madtrout
Re: Open cam chain for 1982 GPZ750?
30 Nov 2018 11:02 - 30 Nov 2018 11:03
I ground off the old link with a Dremel tool. To rivet the new link I bolted a wooden block to the head and braced a small anvil against the gear holding the cam chain. Then I used a small ballpeen hammer to gently flare the rivet ends from the opposite side. You don't need to hit hard, just flare them enough to keep the plate in place.
Last edit: 30 Nov 2018 11:03 by Madtrout.
- Madtrout
07 Mar 2021 07:40 - 07 Mar 2021 07:42
Another long term update. After 25,000 miles on the new cam chain all is well. The old girl now has 113,000 miles on her.
Last edit: 07 Mar 2021 07:42 by Madtrout.
The following user(s) said Thank You: Nessism, TexasKZ, ghostdive
