Open cam chain for 1982 GPZ750?
- Madtrout
31 Oct 2016 07:48 - 31 Oct 2016 07:48
Anyone know where I can buy an open cam chain with rivet master link for a 1982 GPZ750? I want to avoid pulling the crank. Thanks, Mark
Last edit: 31 Oct 2016 07:48 by Madtrout.
Re: Open cam chain for 1982 GPZ750?
31 Oct 2016 07:54
Sounds risky.
31 Oct 2016 08:31 - 31 Oct 2016 08:45Madtrout wrote: Anyone know where I can buy an open cam chain with rivet master link for a 1982 GPZ750? I want to avoid pulling the crank. Thanks, Mark
Nessism is correct about the open-ended cam-chain being more of a risk. But people do it all the time. And are successful when it's carefully and correctly done. Especially when affixing the master link so it doesn't unexpectedly come apart.
Would contact Z1 Parts Inc. See their clickable link at screen bottom. Or just give'em a call. Nice folks to deal with.
Here's another possibility:
www.z1enterprises.com/product/KL12-0408
(Am not positive whether this is the correct part for the bike at hand)
Last edit: 31 Oct 2016 08:45 by Patton.
- Madtrout
31 Oct 2016 09:21 - 31 Oct 2016 09:22
Thanks for your suggestion. I've put an email into Z1enterprises, and will contact Z1parts next.. I've had several bikes with master-links in the cam chain and never had a problem.
Last edit: 31 Oct 2016 09:22 by Madtrout.
31 Oct 2016 10:41
I had one after breaking my chain in 78. Never felt safe with it while at WOT. :pinch: Replaced it in 87 when I did an overhaul. Never do it again. :whistle:
- slmjim+Z1BEBE
31 Oct 2016 12:16
Don't think we'd run a clip link, but we wouldn't hesitate to run a rivet link.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- undiablo
31 Oct 2016 13:15
You can cut the OEM chain (grind the rivets) and install a rivet master link.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- Madtrout
31 Oct 2016 13:17
Thats what the guys at Z1enterprises suggested. Looks like my new plan.
- Madtrout
31 Oct 2016 13:30 - 31 Oct 2016 13:30
My new question is, if the riveted master link doesn't have a dimple like the ones for a drive chain, how do you peen them over? I have the Emgo rivet kit but no experience with peening hard ended pins.
Last edit: 31 Oct 2016 13:30 by Madtrout.
- baldy110
31 Oct 2016 14:31
You use a rivet tool designed for cam chains. All you are really doing is slightly mushrooming the head of the link to prevent it from walking off the link. I have installed dozens of master links on timing chains. Done correctly they are just as good as the endless ones. Never had one fail. Honda used master links in their timing chains on the CB / Cl series of bikes, 350 and 450 twins from the late 60's and early 70's. Each time the head was removed the chain had to be cut and a new master link installed when re-assembled. Honda produced these by the thousands, there was no issue with them breaking.
I have a KZ650 with well over 100,000 miles on it using a master link chain I installed many years ago. I wouldn't hesitate to use one, it has proven to be a reliable and easy fix.
- Madtrout
31 Oct 2016 14:34
Thanks for your reply. So just use the regular rounded tip rivet tool in the kit? The same one I've used with the soft nosed rivets? Thanks, Mark
- baldy110
31 Oct 2016 17:00
Yes but be careful you just want to slightly mushroom the head to much pressure and you will create cracks in the pin. It's really easy to screw it up so take your time and be careful.
