Low RPM knocking
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Low RPM knocking
20 Sep 2016 16:30
#743021
Have you checked the valves? Even rebuilt they can tighten up.
  • chuck hahn
  • chuck hahn's Avatar Topic Author
20 Sep 2016 16:34
#743023
I said the center of the ENGINE..as In if your looking down it from the back right down the center line of the block. I also said to the REAR area of the clutch cover BEHIND the "dome" for a reference if your looking at it from the side of the bike. Nowhere did i say its coming from the center of the clutch COVER.
I have about 3/8 inch free play up at the lever and clutch perch so one would think the pressure plate is NOT being held up from too tight an adjustment or any cable problem. Rides and shifts smooth as silk but I cant stand the low RPM noise.
  • Kray-Z
  • Kray-Z's Avatar
  • I need more power Scotty....
20 Sep 2016 16:34 - 20 Sep 2016 16:40
#743024
swest wrote: Have you checked the valves? Even rebuilt they can tighten up.
And how! If your valve re-surfacing job left very little margin on the valves, or the valve to seat contact is thin and way out on the outer edge with thin or no margins, the valve face / seat wear rate can be really high.... :silly: :silly: :silly:
Last edit: 20 Sep 2016 16:40 by Kray-Z.
  • Kray-Z
  • Kray-Z's Avatar
20 Sep 2016 16:39 - 20 Sep 2016 19:10
#743025
chuck hahn wrote: I said the center of the ENGINE..as In if your looking down it from the back right down the center line of the block. I also said to the REAR area of the clutch cover BEHIND the "dome" for a reference if your looking at it from the side of the bike. Nowhere did i say its coming from the center of the clutch COVER.
O.k. - so.... READ THE FSM and perform an actual CLUTCH FREE PLAY ADJUSTMENT, not a CLUTCH CABLE FREE PLAY ADJUSTMENT....
How many out there believe that cable adjustment and / or play at the lever is proof positive their mechanical linkage or cable actuated clutch is properly adjusted?
Last edit: 20 Sep 2016 19:10 by Kray-Z.
  • SWest
  • SWest's Avatar
  • 10 22 2014
20 Sep 2016 16:43
#743026
From the description it sounds like the bike is stumbling. Could be a lot of things.
  • chuck hahn
20 Sep 2016 17:51 - 20 Sep 2016 17:52
#743033
Stumbling from what though? The timing light doesnt skip or stutter from either coil when I was installing the Dynatek and setting the timing. Nice steady even paced strobe action from the light. I will pull the cover and recheck the valve clearances before restarting it again to eliminate that.
Last edit: 20 Sep 2016 17:52 by chuck hahn.
  • Kray-Z
  • Kray-Z's Avatar
20 Sep 2016 18:10
#743036
Kick starter mechanism?
  • chuck hahn
20 Sep 2016 19:22
#743038
Kicker was stuck when I got the bike. We had to roll the engine over with a wrench to unlock it....so thats a real possibility there. I had kicked it over a few times after that to check that it didnt hang up again and it didnt, But that doesnt mean something isnt askew in there. Thanks for the tip.
  • gdk
  • gdk's Avatar
21 Sep 2016 16:30
#743134
Thanks kraz-z for the tip. I had a late day at work so haven't had time to look at it again. Mine has points, I'm looking in to going electric many next summer.
  • Kray-Z
  • Kray-Z's Avatar
21 Sep 2016 16:54
#743138
Hope that is all there is to it - something that is relatively cheap and easy.
Happy Wrenching! :)
  • Kray-Z
  • Kray-Z's Avatar
21 Sep 2016 16:56
#743139
Oh, nothing really wrong with points if you don't mind doing the upkeep...I like electronic myself as it takes one variable out of the equation most of the time....
  • 750 R1
  • 750 R1's Avatar
21 Sep 2016 18:04
#743145
Kray-Z wrote: If it goes away at 1300, my suspicion is with carb balance and the typical primary chain rattle and clunk....although I can't exclude a bearing failure somewhere in the engine / transmission....
+1, every bike I've had with a primary chain bottom end clunked and rattled at idle, or just above, when the carbs weren't synced properly, on the Honda 4's, both the primary chain and clutch rattle.... ;)
