- Thank you received: 1
Low RPM knocking
- chuck hahn
At any RPM below around 1200 theres a knock that seems to be coming form the back of the tranny area. It goes completely away above 1300 ish and its smooth as silk from there on up.
I have synced and resynced the carbs using the Morgan Carbtune Pro tool I have. thought maybe it was ignition related so I nixxed the points and went to the Dynatek ignition. i thought that maybe it could e clutch basket bearing related but squeezing the cutch lever in and out doesnt seem to change the sound any. Best Youtube Video I could find that sounds close to this knock is here....but I dont thin k its cam chain tensioner related as the sonds coming from the back of the cases and not from the jugs or top end areas.
- Thank you received: 2749
- gdk
- Kray-Z
- I need more power Scotty....
- Thank you received: 107
Have you dropped the oil and checked for metallic residue (silver - grey) in oil or on plug or other signs? Another trick is to cut the oil filter apart on a shallow pan, stretch out the pleats and look for tiny metal bits on the outside surface....
- chuck hahn
As for a video. Aint gonna happen for a while till I get my 82 GPZ1100 off the lift.
- Kray-Z
gdk wrote: Hey Chuck I also have the same knock in my 1979 Sr 650. I brought it to my long time macanic he said that he he had 3 of these bikes and they all did it at low rpm. He says it's just the starter clutch, not to worry, drove his bikes for 20 years and never had an issue at all. I'm not 100% sure that he's right but I hope that helps set your mind at ease.
Both of the 650's I've worked on did this when I got them - the noise went away when the carbs were synched properly....primary chain!
Have had many, MANY Honda fours and CBX's do the same thing, also....
- chuck hahn
- gdk
- Kray-Z
How close are you with the synch? I use mercury tubes and set to within 0.5 cm Hg between all four cylinders. I can get these old bikes running very smoothly (and quietly) by taking my time and using a big fan blowing cooling air to the front of the engine to simulate the bike going about 30 mph - this prevents overheating. You really can't synch the engine properly when it gets too hot. I also use a infra-red thermometer (a really good one held at the same distance for all measurements) on the exhaust headers right out of the head to check the engine's balance at idle.
Other than that, you could be dealing with a loose chain or a damaged bearing....
- Kray-Z
gdk wrote: Thanks good too know. Have no spark in 1 and 4 right now. Thinking it's a coil. Gonna check it out tomorrow in the daylight
A '79? Does it have points or electronic ignition? Check the 1-4 coil first (easy - swap it for 2-3 coil and see if the problem switches cylinders), but if that isn't it, then you might have some loose wiring, or - problem with 1+4 points or 1-4 electronic crank trigger hall effect switch (I have installed many Dyna S ignitions because of the latter).
- chuck hahn
Only reason I was debating opening the clutch cover was to take the basket out and feel for any play in the clucth basket roller bearings or the input shaft bearing
- Kray-Z
It is unusual, but not impossible, that a roller or ball bearing will make a knocking sound only at slow speeds. More likely an anti-friction bearing will produce a whine or a constant humming / growling sound that increases with speed an load.
Now that you say the noise is coming from the center of the clutch cover - I would re-check the clutch adjustment AT THE PUSH ROD under the left side transmission / final drive cover as per the FSM. If you don't have some free play there, the release bearing will be damaged in fairly short order....
Or maybe it was NFG to start with?
