Gpz oiling system vs kz, oil cooler vs non.
- MadShad
10 Sep 2016 11:58
Ok I'll start by saying I'm convinced that I need a larger oil cooler and most likley fittings.
Several people tried to tell me that. (Hi Steve and Lou!)
I also read conflicting info saying my setup would be fine, and that was backed up with the fact that I have a stock Gpz1100 factory oil cooler in my garage to inspect. The factory cooler has a smaller line ID throughout than what I'm using, in fact the smallest opening is around 1/8".
Now I want to know why.
The Z1/KZ pumps are very simple. There's a pressure releif valve in the top of the filter cavity that lets oil back into the pan when pressure gets too high.
On the GPz oil pump that pressure relief valve was moved to the pump and also allows oil back into the pan at a specific pressure, my guess is that its set to open at a higher pressure to deal with pushing oil up and thru the cooler using smaller lines.
Am I making any sense?
Can someone confirm or deny?
The second difference I see is in the filter and the filter bolt itself.
The Z1/KZ part is just a hollow tube with holes for the filter oil to pass thru.
The GPz has a check valve built in that I'm guessing is used to keep the oil cooler oil from draining back out, preventing dry startups.
Confirm deny?
The third difference I'm not sure about, the GPz uses a shorter oil filter with some sort of plate above it.
No Idea why. Higher flow open element? Cheaper or better availability?
Here's what I'm looking at.
And this is the stuff that keeps me up at night, I'm cursed. I just have to know.
Confirm deny?
Shelbyville, Indiana. '80 KZ1000
No more of that talk or I'll put the leeches on you, understand?
- G-tron
Re: Gpz oiling system vs kz, oil cooler vs non.
11 Sep 2016 10:48
Also keen to know.
I'm adding a bigger oil cooler to my KZ750.
Eat, Sleep, Ride
- SmokyOwl
11 Sep 2016 12:15 - 11 Sep 2016 12:18
Also like to learn more about oil coolers, I'd like to add one on my KZ1100. There's a lot of confusion on different models and components required.
1982 Kawasaki KZ1100 A2, Shaft
Never trade the thrill of living for the safety of existance.
Last edit: 11 Sep 2016 12:18 by SmokyOwl.
11 Sep 2016 13:25 - 12 Sep 2016 05:49this reply is not related to the topic post or the 1000/1100.By G-tron: Also keen to know. ... I'm adding a bigger oil cooler to my KZ750.
Just an FYI. the 2000-2005 ZR750 ZR7/ZR7S has a bigger oil pump (more flow) that is a direct bolt-on to the KZ750. pretty sure. There are a couple of topics about it. search for topics by Turboguzzi (sp?). I don't know if blown gaskets are a possibility from the higher flow.
Last edit: 12 Sep 2016 05:49 by martin_csr.
- MadShad
11 Sep 2016 13:28
My questions is very specefic and only pertains to the bikes listed in my original post.
Not the same as the smaller bikes.
11 Sep 2016 14:25MadShad wrote: Ok I'll start by saying I'm convinced that I need a larger oil cooler and most likley fittings.
Confirm deny?
The Z1/KZ oil pump doesn't have a pressure relief valve. That is a bypass valve in case the filter gets clogged. The lines and fittings should not be less than 13mm ID. As for the later pump, I have no experiance with them. It could be they are a higher pressure pump and that is a release valve. I'd like to know more about that system.
- MadShad
11 Sep 2016 14:30
The valve on the kz dumps oil back into the pan' just like the gpz.
I've got my pan off and can see it.
- MadShad
11 Sep 2016 14:43MadShad wrote: The valve on the kz dumps oil back into the pan' just like the gpz.
Just kidding.
I see now that it rerouts back into the oil supply.
That throws my theory out the window and is the info I needed.
Thanks!
11 Sep 2016 15:35
Can anyone with a 1100 share a diagram of the oiling system on their bike?
11 Sep 2016 20:55
- Kray-Z
- I need more power Scotty....
11 Sep 2016 20:55 - 11 Sep 2016 20:58Attachment Kawasakikz10001100.jpg not found
The 81 and up "J" bikes w/o factory oil coolers (above) have a fitting bolted onto the crank case just behind the cylinders that houses the oil pressure sending unit (item no. 11). The oil from the pump and filter pushes the spring plunger on the sending unit open, which breaks the oil light ground circuit and extinguishes the light. The oil then flows directly thru the fitting body to the main oil gallery running transversely behind the cylinders to feed the transmission, crankshaft, and head.
As far as I can tell, the bikes that had a factory cooler (my '83 GPz1100 is one) have a different style fitting bolted to the case top that just directs the flow from the pump up thru the cooler hose lines, where all the oil is pumped thru the cooler, then returns into the main gallery. The '81 and '82 GPz1100's still had an oil pressure sensor there.
Attachment Kawasaki81GPz1100coolerfitting.jpg not found
My 83 GPz1100 does not have an oil pressure sending unit, or light / gauge...it relies only on a low oil level sensor in the sump cover at the bottom of the engine.
Other than the two styles of fittings that bolt to the upper crank case, and the oil level sensor in the sump cover, there is no difference that I'm aware of.....the pumps look identical except for the pressure relief valve fitted to the oil - cooler equipped bikes (at least the two I have sitting on the spare parts shelves in my shop)
GPz:
Attachment Kawasaki81GPz1100OilPump.jpg not found
KZ:
Attachment Kawasakikz10001100OilPump.jpg not found
....I don't think there is any advantage of having the pressure relief valve unless they (Kawasaki) were worried about splitting a cooler hose...
Last edit: 11 Sep 2016 20:58 by Kray-Z.
The following user(s) said Thank You: SWest, MadShad
- MadShad
11 Sep 2016 21:16Kray-Z wrote:Attachment Kawasakikz10001100.jpg not found
Well I can say for sure that the fitting plays a part in why the smaller lines aren't working well on the kz.
The fitting used on the Gpz that route oil to the cooler an back again has a passage that bypasses the cooler.
I have one on the bench (earlier GPz one wth pressure switch) and i just now noticed the passage.
Not ALL of the oil goes thru the cooler.
I'll get a pic
The setup I'm using pushes ALL of the oil up into the cooler, which help explain why gpz oil cooler lines are too small for me to run.
I like your logic in the regulatir valve, that could be it.
