- Thank you received: 104
Spark Plug Gap with Dyna
- bluezbike
-- on a KZ 1000 --
79 KZ 1000 LTD
- KZB2 650
- Thank you received: 265
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- Thank you received: 2749
- Thank you received: 2823
Edit: according to the FSM for the 1000D model bikes the stock gap is .040-.044". That's a big gap. The NGK's come with a smaller gap that that.
- missionkz
Isn't that only .0145"?
Way too small for plug gap.
.037" I could see.
I use .032" on mine with the green coils, but I have tried as wide as .042" and honesty didn't really notice any notable difference, so I'm not a good source of reliable info.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
- bountyhunter
- Thank you received: 337
It'll just shorten coil life by increasing the firing voltage. Spark energy remains the same, no benefit.swest wrote: Just for the hell of, I'm going to try 0.37.
- KZB2 650
1978 KZ650 b-2
- kawi810
- Thank you received: 11
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
- bluezbike
One thing I realize now is the FSM I have was printed in New Zealand so I only have units in metric - kilometers and mm's only.
Bike was running fine til last week then it stated conking out at idle so after checking a bunch of stuff and getting to the spark plugs I found a gap of 1.4 mm. or 0.055" :ohmy: ...... I do not know how it even ran at that setting never mind as well as it did....new plugs set to 0.039" going in tonight.
79 KZ 1000 LTD
- bountyhunter
Longer (length) spark doesn't improve anything, longer time duration doesn't do anything either compared to proper functioning ignition. Considering how easy it is to increase the gap (and voltage) ask yourself: if it added even one tenth HP, don't you think the manufacturer would be using a higher voltage coil setup?KZB2 650 wrote: If I remember right Bounty they said it increased the size of the spark and since the coils put out more voltage they could handle it thus a little bigger (and longer) burn....... .
