Spark Plug Gap with Dyna
- bluezbike
05 Sep 2016 16:45 - 05 Sep 2016 16:45
Is the spark plug gap the same when using either points or Dyna ? 0..35 mm.?
-- on a KZ 1000 --
-- on a KZ 1000 --
79 KZ 1000 LTD
Last edit: 05 Sep 2016 16:45 by bluezbike.
- KZB2 650
Re: Spark Plug Gap with Dyna
05 Sep 2016 17:28
I remember reading in Cycle World in the old days Denco said you could go .037 to .039 with the higher output Dyna coils and pick up a tiny bit of power but most everyone on here (I asked too) recommends the standard .028 to .032. I compromised and go with .032.......... .35mm works out to .013 unless someone corrects that.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
The following user(s) said Thank You: bluezbike
05 Sep 2016 18:33
The Old Kaw Man recommends 0.37- 0.42 with Dyna coils.
05 Sep 2016 18:35 - 06 Sep 2016 11:30
I never gap plugs. Out of the box and into the engine.
Edit: according to the FSM for the 1000D model bikes the stock gap is .040-.044". That's a big gap. The NGK's come with a smaller gap that that.
Last edit: 06 Sep 2016 11:30 by Nessism.
05 Sep 2016 18:50
Just for the hell of, I'm going to try 0.37.
- missionkz
05 Sep 2016 21:47
0.37mm?
Isn't that only .0145"?
Way too small for plug gap.
.037" I could see.
I use .032" on mine with the green coils, but I have tried as wide as .042" and honesty didn't really notice any notable difference, so I'm not a good source of reliable info.
.037" I could see.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- bountyhunter
06 Sep 2016 01:28It'll just shorten coil life by increasing the firing voltage. Spark energy remains the same, no benefit.swest wrote: Just for the hell of, I'm going to try 0.37.
- KZB2 650
06 Sep 2016 07:59 - 06 Sep 2016 08:00
If I remember right Bounty they said it increased the size of the spark and since the coils put out more voltage they could handle it thus a little bigger (and longer) burn....... thinking its such a small difference (I could never feel a diff either of course) you'll never feel it maybe a few thousands of a hp or wishful thinking ??........ I remember my buddy ribbing me about drilling my front disc for weight removal and it not helping but then it was a combination of other things too ..... turn signals, center stand, low bars, air box, header, kick start lever, never more than a gal of gas, alum rear sprocket, smooth bores over stock carbs (2 1/2 lbs) etc etc and every little bit helping and adding up.
1978 KZ650 b-2
Last edit: 06 Sep 2016 08:00 by KZB2 650.
- kawi810
06 Sep 2016 15:23
DYNATEK recomends .035"-.040"that is in thousands of a inch.old man kaw says .037"-.042" thous. some times we get mm's and decimal points mixed up.my fsm manual for a gpz 750 say .7-.8 mm =.027"-.031"thous i hope this clears things up.
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
06 Sep 2016 15:42
Yeah, it's .037. :blush:
- bluezbike
07 Sep 2016 20:04 - 07 Sep 2016 20:05
Thank you all for the replies....I got my units in a twist......it is 0.7 - 0.8 mm. (not 0.035 mm)
One thing I realize now is the FSM I have was printed in New Zealand so I only have units in metric - kilometers and mm's only.
Bike was running fine til last week then it stated conking out at idle so after checking a bunch of stuff and getting to the spark plugs I found a gap of 1.4 mm. or 0.055" :ohmy: ...... I do not know how it even ran at that setting never mind as well as it did....new plugs set to 0.039" going in tonight.
79 KZ 1000 LTD
Last edit: 07 Sep 2016 20:05 by bluezbike.
- bountyhunter
07 Sep 2016 21:34Longer (length) spark doesn't improve anything, longer time duration doesn't do anything either compared to proper functioning ignition. Considering how easy it is to increase the gap (and voltage) ask yourself: if it added even one tenth HP, don't you think the manufacturer would be using a higher voltage coil setup?KZB2 650 wrote: If I remember right Bounty they said it increased the size of the spark and since the coils put out more voltage they could handle it thus a little bigger (and longer) burn....... .
