Weird Sound Starting a KZ750 H1
- donconcha
- Yop
04 Sep 2016 09:13 - 04 Sep 2016 09:52
I recently change the rings of the pistons and the oil seals of the valves. It's a 80's Kz750 H1 .
The engine makes a weird sound when it runs. It's like a Sucking sound.
The carb float puts to much gasoline in the 4th cylinder. the sound comes from the 3rd cylinder
I need Some advice about this. is it possible to be a timing problem?
Ignore the Carb malfuntion.
KZ 750 LTD H1 - 80
ZR 550 Zephyr 91
ZR 550 Zephyr 91
Last edit: 04 Sep 2016 09:52 by donconcha.
- donconcha
- Yop
Re: Weird Sound Starting a KZ750 H1
04 Sep 2016 11:51
The sound is like a burble.
KZ 750 LTD H1 - 80
ZR 550 Zephyr 91
ZR 550 Zephyr 91
04 Sep 2016 13:40donconcha wrote: I recently change the rings of the pistons and the oil seals of the valves. It's a 80's Kz750 H1 .
Why are you running it with no pipes? You want to warp the valves? Maybe already done.
- baldy110
04 Sep 2016 14:30
You will never be able to diagnose a running issue without the exhaust and carbs hooked up correctly.
- donconcha
- Yop
04 Sep 2016 14:42 - 04 Sep 2016 14:43i Have no idea that this could happend. :blink:swest wrote:donconcha wrote: I recently change the rings of the pistons and the oil seals of the valves. It's a 80's Kz750 H1 .
Thanks for the advise.
KZ 750 LTD H1 - 80
ZR 550 Zephyr 91
ZR 550 Zephyr 91
Last edit: 04 Sep 2016 14:43 by donconcha.
- donconcha
- Yop
04 Sep 2016 14:44baldy110 wrote: You will never be able to diagnose a running issue without the exhaust and carbs hooked up correctly.
i Will Fix it today. Do you think this burble sound will be fix with the exhaust on it?
KZ 750 LTD H1 - 80
ZR 550 Zephyr 91
ZR 550 Zephyr 91
04 Sep 2016 14:44
There is no way any carburetor will work properly under those conditions. Without a proper exhaust system and intake system, reversion impulses will blow air/fuel mixture backwards out of the carbs. When there happens to be enough mixture in the chamber for detonation, it will be a dangerously lean mixture that can cause serious damage. Please put it all back together before trying to run the engine again.
04 Sep 2016 14:51donconcha wrote:baldy110 wrote: You will never be able to diagnose a running issue without the exhaust and carbs hooked up correctly.
Maybe. Be sure to install new crush washers where the pipes bolt to the head. If the old ones are in decent shape, you may be able to anneal them and reuse them.
04 Sep 2016 15:51 - 04 Sep 2016 15:53
Good grief guy! You ran the engine with no exhaust and wonder why it sounds horrible? You gotta be kidding us - right? :blink:
The only other time I saw anyone try that was when I was 15 and my 16 year old buddy did that with his Honda CB-160 in his parent's basement. His mother went berserk when she heard it because she thought he was messing with her clothes washing machine (no kidding). :laugh: Ed
Last edit: 04 Sep 2016 15:53 by 650ed.
- donconcha
- Yop
04 Sep 2016 15:57650ed wrote: Good grief guy! You ran the engine with no exhaust and wonder why it sounds horrible? You gotta be kidding us - right? :blink:
i was not kidding... i'm pretty new in all this stuff about motors and motorcycle. Have no idea. :blink:
KZ 750 LTD H1 - 80
ZR 550 Zephyr 91
ZR 550 Zephyr 91
- donconcha
- Yop
04 Sep 2016 15:58TexasKZ wrote:donconcha wrote:baldy110 wrote: You will never be able to diagnose a running issue without the exhaust and carbs hooked up correctly.
i will ! Thanks for the advice
KZ 750 LTD H1 - 80
ZR 550 Zephyr 91
ZR 550 Zephyr 91
04 Sep 2016 16:10
There will be people that will give you bum advice just to see you fail. :dry: If a "biker" tells you to do something, throw it up here, we'll tell you if it's BS or not.
