KZ1000 exhaust sealing problem
  • westmiltonfab
  • westmiltonfab's Avatar Topic Author
02 Sep 2016 05:10 - 02 Sep 2016 05:11
#740857
I am in the process of putting my KZ back to stock and I am having a rough time with the stock exhaust. What is the best procedure ? I can not get the pipes to seat against the head. The flanges do not seam to pull the pipes forward to aid in the sealing process.
Thanks for your help.
Bill
1980 Kz1000 A4 21000 miles
2005 Road King 150,000 miles
1968 CL125 Honda 11,000 Miles
Last edit: 02 Sep 2016 05:11 by westmiltonfab.
Re: KZ1000 exhaust sealing problem
02 Sep 2016 05:39
#740860
Good Fortune! :)
The following user(s) said Thank You: westmiltonfab
  • SWest
  • SWest's Avatar
  • 10 22 2014
02 Sep 2016 05:39
#740861
New crush gaskets? What kind of pipes? Pics? They fit into a recess so it is possible to get them off center and not tighten down all the way. I had to double mine up for my V/H.
02 Sep 2016 05:48 - 02 Sep 2016 05:49
#740864
Make sure gaskets are not already stuck inside the head. Use new gaskets and make sure you have stocksplit collars rather than collars from an after market pipe. Some aftermarket pipes use collars that are a different length than the stock ones so they don't work properly with stock pipes. Ed
Attachment 00003a-2-3-4-5-6-7-8-9-10-11-12-13-14-15-16-17-18-19-20-21-22-23-24-25-26-27-28-29-30-31-32-33-34-35-36-37-38-39-40-41-42-43-44-45-46-47-48-49-50-51-52-53-54-55-56-57-58-59-60-61-62-63-64-65-66-67-68-69-70.jpg not found
Last edit: 02 Sep 2016 05:49 by 650ed.
  • westmiltonfab
02 Sep 2016 05:58
#740868
The diagram sais it all. Thanks guys!
  • westmiltonfab
02 Sep 2016 06:02
#740870
The used exhaust that I purchased had collars with it. I will use those. Thanks for the advice.
02 Sep 2016 06:43
#740878
Another reason for varying split collar lengths --
Good Fortune! :)
  • MDZ1rider
  • MDZ1rider's Avatar
02 Sep 2016 08:22
#740895
Not specific to your sealing issue, but a trick I used to make the actual installation easier...
Secure the split collars to the head pipe with a loop of safety wire at the collars flange end. There's usually a small gap between the collars to tuck the safety wire twist into. Remember to slide the finned retainer over the head pipe before wiring the collars.
02 Sep 2016 08:35
#740900
MDZ1rider wrote: Not specific to your sealing issue, but a trick I used to make the actual installation easier... Secure the split collars to the head pipe with a loop of safety wire at the collars flange end....
Or use the time-honored masking tape technique, which will soon burn off.
Good Fortune! :)
  • westmiltonfab
07 Sep 2016 11:37
#741434
The pipes are on thanks everyone. Now I am replacing pods with the stock air box and silencer. I cleaned and re jetted the carbs. Now my question is how the heck do I get that put back together? I did a Honda 550 once but I was a kid back then. Do I put the air box boots on first or after I get the carbs mounted?
Thanks in advance. I want to post pictures but I keep getting errors as they are too big.
  • SWest
  • SWest's Avatar
  • 10 22 2014
07 Sep 2016 11:40
#741435
Box in the frame with the boots then install the carbs.
  • westmiltonfab
07 Sep 2016 11:59
#741439
Every boot at the same time? or focus on the more pliable air box boots first?
