Cam cover bolt threaded hole repair
  • diego092409
  • diego092409's Avatar Topic Author
Re: Cam cover bolt threaded hole repair
16 Aug 2017 16:57
#769130
Finally got the jugs back in and noticed that the tappet for the #3 exhaust valve was tight. Wouldn't rotate freely. This is the tappet closest to the repaired hole. I would like to pull this tappet and rehone the socket. Since it appears to have become slightly distorted. Any tips for removing the tappet short of drilling out the valve.
1982 KZ1100 B2 - 'Old Red' kzrider.com/forum/11-projects/601185-gpz-1100-resto-mod-old-red
2015 BMW K1600GT
2017 KTM 690 Enduro R
2018 Kymco Spade (wife's)
  • KZB2 650
  • KZB2 650's Avatar
17 Aug 2017 06:11
#769148
Either a good suction cup or I had to use a strong magnet once..... couldn't seem to grab it with pliers ..... always used a smaller weaker magnet for shim replacement but some say on here it will cause it to remain magnetised and maybe draw in shaving of metal but I'm not to worried about that. Mine had a small nick on the bore that I had to gently file down after APE replaced the guides.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
17 Aug 2017 07:21
#769149
Be careful about using a magnet on it if you plan to reuse the bucket. A magnet might somewhat magnetize it in which case any metallic sludge might tend to stick to it. If that was to happen it could accelerate wear on the bucket and/or cam lobe. Ed
  • diego092409
17 Aug 2017 12:50
#769159
due to having new valve seals and the generally crudiness of the engine, I am going to pull the valves and clean it it before putting it back on the bike. This is the last time it is coming off (I hope). I think I am going to cut off the valve and tap out the stem. using the spring to pull out the tappet. I don't want to be playing with this again.
2015 BMW K1600GT
  • SWest
  • SWest's Avatar
  • 10 22 2014
17 Aug 2017 15:21 - 17 Aug 2017 15:22
#769167
Could be a sliver of metal. I wouldn't go that far. I had it happen and worked the lifter out little by little, cleaned it up good and slid it back in.
Last edit: 17 Aug 2017 15:22 by SWest.
  • JR
  • JR's Avatar
17 Aug 2017 17:05
#769169
I use a strong magnet to pull the buckets and never had a problem or hint of a problem. Never a sign the buckets become magnetised (shims wont stick to inside without magnet on outsde) and no sign of metallic particles sticking.
It might be different if I stroked the bucket in the same direction with the magnet. As it is pulling a bucket is only necessary maybe once every couple of years
  • diego092409
17 Aug 2017 19:02
#769175
Tried channellocks to no avail, so I tacked a 6mm bolt onto it and had it out in a min. I saw the buckets are readily available on ebay so going to clean it up, use the old tappet to check it and put the new bucket in. See attached to see the final repaired hole. Put and insert in right away
2015 BMW K1600GT
