Cam cover bolt threaded hole repair
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Cam cover bolt threaded hole repair
07 Aug 2016 17:34
#737752
Pics? Might be able to reuse the rings. I'd give it a nice cross hatch to help them reseat. Valve guide seals at least. Lets see what you have to work with. B)
  • diego092409
  • diego092409's Avatar Topic Author
07 Aug 2016 18:16 - 07 Aug 2016 18:20
#737758
Freshly taken pics of pistons 1 and 2.
1982 KZ1100 B2 - 'Old Red' kzrider.com/forum/11-projects/601185-gpz-1100-resto-mod-old-red
2015 BMW K1600GT
2017 KTM 690 Enduro R
2018 Kymco Spade (wife's)
Last edit: 07 Aug 2016 18:20 by diego092409.
  • SWest
  • SWest's Avatar
  • 10 22 2014
07 Aug 2016 18:20
#737760
Looks like your rings weren't seating. Could be the guide seals too. Pis of the bores? Replace the seals and you can look at the valves.
  • diego092409
07 Aug 2016 18:42
#737764
I have the seals so that I can replace them.
Those are the stock rings. First time the jugs are off to my knowledge. Not sure what you mean by they're not seating. I see the top ring is sprung a little and is off center on the piston.
What should I be looking at when I pull the valves?
2015 BMW K1600GT
  • SWest
  • SWest's Avatar
  • 10 22 2014
07 Aug 2016 18:49
#737766
The clean ring around the tops of the pistons suggests to me they weren't seating. You're going to this much trouble, new rings would make sense. With 28k on the engine, you may have to have the valve and seats ground. Take them out and see.
  • diego092409
16 Aug 2016 15:13
#738929
Any leads on economical after market rings? I found some on eBay for all four that is the same price that Z1 sells 1 set of rings. I hadn't anticipated taking the jugs off and doing this...
For the price that I am looking at a set of rings from Partzilla or Z1enterprises, I could almost buy a big bore forseti big bore piston kit with rings; not that I am looking to bore out my engine. I just would like a source of rings that will meet my needs without costing an arm and a leg. I had torn it down just to keep it from leaking.
2015 BMW K1600GT
  • SWest
  • SWest's Avatar
  • 10 22 2014
16 Aug 2016 15:26
#738933
What are we talking a set of rings vs the piston kit? I suspect the kit will be inferior to the stock parts. Links?
  • diego092409
16 Aug 2016 17:45
#738953
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationMost economical piston ring set I have found.
Look at this on eBay
Big bore piston set from the same company
Machined die cast big bore piston kit
www.japbikespares.com/kawasaki/kawasaki-...-1170cc-big-bore-kit
Please keep in mind my goal is a tight reliable engine but I doubt I will even get to 1k miles once it's together.
I took some other pictures of the existing rings from a top down angle. Please provide your observations but there appears to be seating grooves in the rings.
2015 BMW K1600GT
  • SWest
  • SWest's Avatar
  • 10 22 2014
16 Aug 2016 17:59
#738957
Z1E sold me rings for my Wiseco pistons at $12 a set. X 4 isn't a whole lot more than those cheap rings. 4 pistons complete with everything $500. I know the name and know the product. That set for under $400 not only is standard compression but are not forged ether.
If it were me, I'd use a feeler gauge on the rings in their lands to see if they're in spec. If the rings have wear marks, the pistons might still be good. New rings might save you a bundle. If new pistons and bore is called for, I'd get 10.25/1 Wiseco's. Take that advice and you won't regret it. :whistle:
  • diego092409
16 Aug 2016 18:06
#738959
Steve,
Believe me I am very tempted to put in oversize higher compression pistons. I don't know how I would explain that purchase to my supportive wife who would prefer to spend that money on a GPS for the beemer....
I realize the foresti pistons don't hold any water to wiseco or mtc pistons.
2015 BMW K1600GT
  • SWest
  • SWest's Avatar
  • 10 22 2014
16 Aug 2016 18:08
#738961
Pics of the bores?
  • diego092409
17 Aug 2016 03:20
#738992
I don't know how much can be divined from these pics of the jugs. I oiled them when I took them off to keep them from rusting.
2015 BMW K1600GT
