Oil in Fuel ?
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
Oil in Fuel ?
07 Jul 2016 17:21
#734189
I have now ridden my 77' KZ100A that I've been working on for just over 400 miles. Other than measured low compression its a gauge as I stated earlier, it run's pretty decent.
Only thing that perplexes me is that there is a clear oil presence in the gas when I wipe my finger under the overflow fuel nipples at the bottom of the float bowls of the carburetors ? This is when the bike is parked after a ride. At one time I was concerned when I would find fuel on the ground under the bike at times but turned out to be a slow leaking fuel petcock which now has been repaired. Incidentally the float levels are correct with the clear tube method.
Granted there's not much fuel found at the overflow nipples, just a small drop on my fingertip. But never the less there is oil present.
Any Ideas ???
77' KZ1000A
  • missionkz
  • missionkz's Avatar
Re: Oil in Fuel ?
07 Jul 2016 17:36
#734190
Stock air cleaner assembly and oil separator canister hook up?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
  • kzdcw
  • 77' KZ1000A
Re: Oil in Fuel ?
07 Jul 2016 20:02
#734199
Crankcase Oil Breather not hooked up. Running K&N air filter pods ( 2 ). No stock air cleaner assembly.
I see no oil spray coming out of crankcase oil breather top tube ?
77' KZ1000A
Re: Oil in Fuel ?
07 Jul 2016 20:14
#734203
Possibly from pods having been over-oiled?
Good Fortune! :)
  • kzdcw
  • 77' KZ1000A
Re: Oil in Fuel ?
07 Jul 2016 20:20
#734204
Never treated the Pods with oil. I was going to when I first installed them but didn't. Normally the K&N oil spray in Red in color when you that the air filters. The pods I received looked like they never were treated at all.
The oil in the gas appears clear and kind of yellowish brown in color.
Should the oil breather tube have a filter on it ? I just left it open to vent into the atmosphere. And as I said when I swipe my finger over the vent tube, there's no oil trace. Nor do I see any oil spray inside the carburetor or engine area.
77' KZ1000A
Re: Oil in Fuel ?
07 Jul 2016 20:58 - 08 Jul 2016 18:59
#734208
kzdcw wrote: . . . Should the oil breather tube have a filter on it ? I just left it open to vent into the atmosphere. . . .
Should the oil breather tube have a filter on it ? -- NO. Such filters are IMO worthless trouble-makers.
I just left it open to vent into the atmosphere -- That's just fine. :cheer:
Good Fortune! :)
Last edit: 08 Jul 2016 18:59 by Patton.
  • Tyrell Corp
  • Tyrell Corp's Avatar
Re: Oil in Fuel ?
08 Jul 2016 05:07
#734225
Your oil mist is condensing on the cold carb bowls, a length of hose from breather vent to a beer can catch tank is the usual way to do it. You will get a small amount oil collecting in it.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Oil in Fuel ?
08 Jul 2016 06:27
#734230
I had the hose routed up then down to the chain. A oil mist would be good for it.
  • Nessism
  • Nessism's Avatar
Re: Oil in Fuel ?
08 Jul 2016 07:53
#734237
I tend to doubt you actually have oil getting into the fuel. Fuel in the oil on the other hand is quite common when the carbs are overflowing like you mention. Sometimes when the petcock fails there is fuel flowing backwards down the vacuum line and into the carbs that way too.
Re: Oil in Fuel ?
08 Jul 2016 15:43 - 08 Jul 2016 19:15
#734280
True. My BSA Cyclone engine had the breather tube on a port in the engine case directly above the counter sprocket to keep the chain lubed. Ed
Last edit: 08 Jul 2016 19:15 by 650ed.
  • TexasKZ
  • TexasKZ's Avatar
Re: Oil in Fuel ?
08 Jul 2016 16:49
#734290
Could be some contaminate in the fuel tank.
Re: Oil in Fuel ?
08 Jul 2016 19:03
#734318
Good Fortune! :)
The following user(s) said Thank You: GPz550D1, BIKEMECHANIC73
