Using the Cam Chain Tensioner
- SmokyOwl
Re: Using the Cam Chain Tensioner
09 Jul 2016 12:41Nessism wrote: Please go back and read what I wrote.
Leave the valve cover in place but remove the tensioner spring cap and spring, and pull the cross wedge back. Then reinstall them all and you are done.
You need a 17mm socket and a long extension. Go ahead and remove that spring cap and you will see what I mean. And don't forget to pull out the cross wedges a small amount, but don't rotate it. Then just reinstall the parts again and you are done.
Tried that, found the dowel pin to be off-horizontal by about 10 to 15 degrees. Removed it, lubricated it, reinstalled everything. No change.
1982 Kawasaki KZ1100 A2, Shaft
Never trade the thrill of living for the safety of existance.
09 Jul 2016 13:38
Take the valve cover off to inspect for damage before disaster strikes. If you have to pull the carbs then so be it. I'm thinking a broken guide.
- daveo
09 Jul 2016 16:09swest wrote: Take the valve cover off to inspect for damage before disaster strikes. If you have to pull the carbs then so be it. I'm thinking a broken guide.
Those guides...the head has to come off to replace the front and rear. The cams will have to come out just to examine them. Perhaps you could see the back of the rear guide by removing the tensioner, and looking through the tensioner hole.
The upper chain guide in the cam cover is likely fine.
I would get an APE manual-tensioner vs. a knock off brand for a few dollars less.
1982 KZ1100-A2/1170 sleeper 😀
