Accidentally used 10w-30 Mobil 1 synthetic...
- Zaddict
- Enjoying my Zaddiction!
18 Jun 2016 09:43
...instead of 10w-40 Mobil 1 synthetic for motorcycles. Only noticed my mistake after I'd changed the oil. I understand there may be some issues with clutch slip/wear? Do I need to change the oil? Kicking myself...
1990 Zephyr zr550 B1
Wiseco 615cc kit
zx550 cams
SPII ignition system
Kerker stainless steel race exhaust with 1.5" competition baffle
K&N Air Filter...
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
Re: Accidentally used 10w-30 Mobil 1 synthetic...
18 Jun 2016 09:49
I doubt it. Just change it early.
18 Jun 2016 11:20Zaddict wrote: ...instead of 10w-40 Mobil 1 synthetic for motorcycles. Only noticed my mistake after I'd changed the oil. I understand there may be some issues with clutch slip/wear? Do I need to change the oil? Kicking myself...
If the oil in your bike is meant for newer cars with catalytic converter, AND the container talks about friction modifiers and is NOT meant for a wet clutch then change it now. These car oils have little or no zinc and that is a bad thing.
OR listen to Steve :pinch:
- KZB2 650
18 Jun 2016 11:59
Since you caught it right at least you could use it in your car..... that's what I use in mine only 5/30.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
18 Jun 2016 12:09
I ran modern oil in my bike for a year then switched to Rotilla. No damage but the bike burned oil then stopped.
- bountyhunter
18 Jun 2016 12:43 - 18 Jun 2016 12:44If it says "energy conserving" on the can you need to dump it because it has the moly in it that can screw up a clutch. Check the can.Zaddict wrote: ...instead of 10w-40 Mobil 1 synthetic for motorcycles. Only noticed my mistake after I'd changed the oil. I understand there may be some issues with clutch slip/wear? Do I need to change the oil? Kicking myself...
Last edit: 18 Jun 2016 12:44 by bountyhunter.
- bountyhunter
18 Jun 2016 12:47 - 18 Jun 2016 12:47But it's easy to add.Street Fighter LTD wrote: These car oils have little or no zinc and that is a bad thing.
Last edit: 18 Jun 2016 12:47 by bountyhunter.
- Zaddict
18 Jun 2016 16:51
OK, thanks for the advice all. I didn't see "energy conserving" on the label and the bike seems to be riding fine. I think I'll take Steve's advice and just change the oil early.
Cheers,
Mark
Cheers,
Mark
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
- bountyhunter
18 Jun 2016 17:07 - 18 Jun 2016 17:08I think you dodged a bullet. One thing to consider, it probably is low on zinc. If you want to run it a while (I would) you can bump the zinc maybe 600 - 800 ppm by dumping in half a can of STP oil treatment (the high mileage stuff). Most car oils now have about 600 ppm so a 600 ppm increase takes it up to where it should be. The STP will also bump the viscosity of the oil a bit and make 10-30 more like 15-35 which is closer to what you want anyway.Zaddict wrote: OK, thanks for the advice all. I didn't see "energy conserving" on the label
Last edit: 18 Jun 2016 17:08 by bountyhunter.
18 Jun 2016 20:23
The OP says Mobil 1 for motorcycles. If that is true, there is no problem.
- Zaddict
18 Jun 2016 20:27
Meh, looks like I spoke too soon - doublechecked the label and it didn't say "energy conserving" but it did say "resource conserving", which apparently is the new and improved energy conserving.
I'll replace the oil and put the 10W-30 in my Land Cruiser. No big deal, I think.
I did take the bike out for a quick ride and didn't notice any difference; other than the fact that it's running great after putting in new jets. Will be installing a Kerker exhaust next weekend
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
Wiseco 615cc kit
zx550 cams
K&N Air Filter...
18 Jun 2016 20:37
You may have to go up a step on the pilots and mains.
