Adding kick start on a Kz750E
  • DoctoRot
  • DoctoRot's Avatar
Re: Adding kick start on a Kz750E
25 May 2016 22:52 - 25 May 2016 22:54
#728600
all you need is the kick-starter assembly and clutch cover from a 650. You will have to split the cases to install it.
Last edit: 25 May 2016 22:54 by DoctoRot.
  • Mickey1031
  • Mickey1031's Avatar Topic Author
25 May 2016 22:57
#728601
AWSOME thank you
The difference between a "biker" and a real Biker, saying you own a bike, and actually owning a bike, Not a "T" shirt
  • SWest
  • SWest's Avatar
  • 10 22 2014
26 May 2016 05:38
#728614
If I had a smaller four I'd do it. I always thought doing away with it was stupid. I didn't know the smaller fours were prone to starter problems and what a PITA it is to fix them. :unsure: The large four starters are so dependable it's not an issue but I wouldn't get rid of mine. Pulled my fat out of the fire countless times in 40 years. :whistle:
  • Mickey1031
27 May 2016 04:08
#728783
Never understood it either have had enough power for it to run but not to start so a kick would allow you to get it started.
This is why I'd like to have that option.
  • martin_csr
  • martin_csr's Avatar
27 May 2016 05:25
#728791
The bike should start with just a touch of the start button in warm weather and within no more than a few seconds when it's cold. If the motorcycle is having starting problems, you should figure that out first. The bike needs a good fully charged battery to run right & the charging system should be working properly. A good smart charger is handy to keep the battery charged during periods of down time if the battery voltage drops from not riding the bike.
  • Mickey1031
27 May 2016 05:47
#728796
Oh agree. But I have had this in the past.
This one might be diffrent
But it's always been cold blodded
  • riturbo
  • riturbo's Avatar
28 May 2016 06:25
#728938
smokie on the turbo site has one .
Attachment smokiesturbo.jpg not found
Attachment smokiesturbo1.jpg not found
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
