Found something terrifying in my oil pan
  • Yetanotherkzrider
  • Yetanotherkzrider's Avatar Topic Author
16 May 2016 19:26
#726881
Changed my oil today and found this. Looks like a cam guide. How f*cked am I?
  • Nessism
  • Nessism's Avatar
Re: Found something terrifying in my oil pan
16 May 2016 19:34
#726883
Looks like a chunk of cam chain guide.
  • Yetanotherkzrider
16 May 2016 19:42
#726888
Are there multiple guides in the mkii engines? I'm getting ready to order some parts and don't want to miss anything.
  • SWest
  • SWest's Avatar
  • 10 22 2014
16 May 2016 19:44
#726891
Pull the head and check the damage.
16 May 2016 20:08
#726896
Yetanotherkzrider wrote: Are there multiple guides in the mkii engines? I'm getting ready to order some parts and don't want to miss anything.
Find your model in the link below and check out the diagrams; they should show all the guides. Ed
www.powersportswarehouse.com/p/Kawasaki#/s/KUS/kz1000//1
The following user(s) said Thank You: Yetanotherkzrider
  • missionkz
  • missionkz's Avatar
16 May 2016 21:11 - 16 May 2016 21:12
#726903
Yetanotherkzrider wrote: Changed my oil today and found this. Looks like a cam guide. How f*cked am I?
Ouch! I think three things cause this.... No timely cam chain tension adjustments or mis adjusted and over revving.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: 16 May 2016 21:12 by missionkz.
  • Yetanotherkzrider
16 May 2016 21:20
#726904
I installed a manual tensioner last summer, maybe I tightened it too much. Bike does have 65k on it. Scary thing is that right up to the point where I drained the oil today it ran fine and didn't make any noise. I'll be tearing into it first thing in the morning, hoping for the best.
  • SWest
  • SWest's Avatar
  • 10 22 2014
16 May 2016 21:29
#726906
The rest og the guides/rollers if any need to be replaced. If yours has rollers you can buy new billet ones at 1/2 the price of OEM and they will last much longer.
kzrider.com/forum/2-engine/597654-poser?start=80#690209
  • Yetanotherkzrider
16 May 2016 22:02
#726908
swest wrote: The rest og the guides/rollers if any need to be replaced. If yours has rollers you can buy new billet ones at 1/2 the price of OEM and they will last much longer.
Ouch. I'm really hoping I don't have that much damage. This is my only vehicle at the moment and I dont have tons of time and money to spare.
  • missionkz
16 May 2016 22:55
#726912
Well, you have to remove the head to fixed this and replace the parts. If you haven't heard the chain slap and grinding, you probably just lucked out and have not put too many miles on it
You'll probably find where the chain has ground into some of the cam chain tunnel areas
Bruce
1977 KZ1000A1
  • Yetanotherkzrider
17 May 2016 01:08
#726916
Sounds like I have a busy day or two ahead. Fingers crossed I didn't mess up anything other than some rollers.
  • Yetanotherkzrider
17 May 2016 10:00
#726991
Turns out it was definitely the cam Chain guide. The center popped right out of it. Some of the idlers and rollers are shot.so I'm looking at replacing them, the cam chain, re-ringing the pistons, etc. Any help or advice with this is appreciated. Not sure how much slack I should have had on the chain after removing the idler so I took a pic. Hoping I can avoid replacing it.
