uneven idle after warm up
- BIKEMECHANIC73
15 May 2016 19:51
Howdy all,
Looking for some help on what most likely may be the issue here.. The problem is, on cold start, I full choke the carbs & bike usually starts right up & will semi slowly (lol) run up to about 4000 - 4500 rpm. (is that good?). Once I bring the choke down halfway & then a couple minutes later all the way down & bike idles well. So, I'll go out for a spin, mostly country side & behaving myself somewhat on speed.. When I come to a stop at a light or whatever, the bike wont idle steady.. The bike will idle steady for a bit then make a "spit" (like noise), idle low, then idle up a bit, then back down or steady & so fourth.. I have just cleaned the carbs, spark plugs are gaped properly (haven't checked coloration on plugs in at least 3 months), carbs have UNI foam hi flow air filters, & Jardin side cut pipes. Carbs have also been jetted properly. I have noticed some minor cracking on the intake manifolds where they mount. I have been told it may be valve clearances, but I'm not sure. Also, could this be a points issue? Any input would be Greatly appreciated.
Thanks!
P.S. I keep getting this message when I try to post a pic of my Bike "Attachment image size exceed limit allowed by configuration"
Thanks!
They ain't related, but they Doobie Brothers..
Re: uneven idle after warm up
15 May 2016 19:57
Air leak, spark advance sticking, valves out of adjustment, carbs out of sync.
The following user(s) said Thank You: BIKEMECHANIC73
- BIKEMECHANIC73
15 May 2016 20:03
Spark advance would be points? Sorry, just not too hip on technical wording.. (guess that should be the first thing i fix lol)
15 May 2016 20:05
It should be lubed and move freely. The springs might be stretched.
15 May 2016 20:47
If the carb holders (between the carbs and cylinder head) let any air leak in the idle will be erratic. Try this:
Make sure the vacuum caps are tight on the carb holder nipples.
Warm the engine up to normal operating temperature.
Temporarily set the idle as low as possible without stalling the engine. It should be down below 1000 rpm. The lower the better because when it is set low the carb slides are closed (or nearly closed) and this raises the vacuum level in the carb holders. The combination of the increased carb holder vacuum level and the very low idle amplifies the effect of the leak test.
Once the idle is set low, spray carb cleaner around each of the carb holders where they bolt to the cylinder head and where the carbs attach to them. If there are leaks, the vacuum in the carb holders will suck the carb cleaner in and this will affect the idle. It may cause the engine to stall. If the leaks are at the carb holder / cylinder head mating surface you need to replace the holders. If the leak is where the carbs attach to the holders you may be able to tighten the clamps enough to seal the leak. Some folks use starter fluid or other substances for the test, but carb cleaner works best as it doesn’t evaporate too quickly like ether and leaves no residue on the engine like WD40.
If you do need new holders just bite the bullet and buy them. Trying to seal things up with some kind of sealant or goop will only lead to frustration as it will at best only last a short time.
- BIKEMECHANIC73
15 May 2016 20:59
Thanks 650Ed! I'll give that a shot first thing tomorrow! That may be the culprit because it ran fine until time before last when I removed the carbs for cleaning. Is there a "Best" way to reinsert & tighten the carbs into the holders?
15 May 2016 21:00
I use a smear of grease in the holders.
15 May 2016 21:04
I spritz the holders with Armor All.
15 May 2016 21:06BIKEMECHANIC73 wrote: . . . I keep getting this message when I try to post a pic of my Bike "Attachment image size exceed limit allowed by configuration"
- BIKEMECHANIC73
16 May 2016 00:22Attachment 1978KawasakiKZ650.jpg not found
16 May 2016 09:51 - 16 May 2016 09:52BIKEMECHANIC73 wrote:Attachment 1978KawasakiKZ650.jpg not found
Pic in above quote is JPEG 225px x 300px.
Here it is in JPEG 450px x 600px.
Here it is in JPEG 900px x 1200px.
2400px is the maximum width size for an embedded image.
1200px is the maximum vertical size for an embedded image.
Sizes that exceed 2400px width by 1200px vertical, or slightly exceed either of those dimensions, may be automatically resized in a forum post, but attempts to embed grossly oversized pics will usually produce an error message.
Last edit: 16 May 2016 09:52 by Patton.
16 May 2016 10:05 - 16 May 2016 10:07
For more re-sizing info, check out the following links:
www.kzrider.com/forum/8-about-the-site/5...posting-pics-is-easy
www.kzrider.com/forum/8-about-the-site/4...qpaintq-in-windows-7
Last edit: 16 May 2016 10:07 by Patton.
