uneven idle after warm up
- BIKEMECHANIC73
Re: uneven idle after warm up
16 May 2016 16:10
Ok, here's an update..
First things first.. Checked the holders & the clamps for 2 & 3 were caught up on part of the carb frame & not tightened all the way, so I made adjustments & re-tightened clamps. Next I warmed up the engine idled down to lowest Idle point to check for leaks, & using carb cleaner, no leaks!! Victory #1!! After that, I removed the points cover, checked points gap & reset to 0.014 (0.012-0.016 so i went in the middle). Finally. cleaned the points, gaped & installed new spark plugs (Why not right? lol).. Problem problem solved!! I want to sincerely Thank all of you who commented & advised me!! We should have some kind of rally or meeting point so all us KZ guys can hang out & shoot the breeze!! Thanks again!!
They ain't related, but they Doobie Brothers..
16 May 2016 17:09
Good job! Ed
