zr7 motor in KZ750
- turboguzzi
zr7 motor in KZ750
04 May 2016 14:25 - 04 May 2016 14:29
well, in a nutshell, it fits!
funny that when i went searching here, never seen one done before.... maybe because in the US the zr-7 was not sold that much? here in europe they were quite popular for a long time. you can get well kept samples for as little as 1100$
the original 80K miles motor in my 750 was actually OK until it developed a leak in the cyl base gasket, well it's time to pull out the zr7, 15K miles, hardly run-in motor i found in a swap meet fot 200$
so, yes, it fits, but quite a lot of stuff had to be modified, definitely NOT a drop in and drive. took a weekend + a week of after work nights to finish, spacers on the lathe, etc.
but also quite a lot of reasons to do the swap: much fresher motors, primary chain tensioner (way quieter), improved sealing in the half moons area, rack and pinion clutch actuator (like half the effort of the kz750 at the lever), sturdy 8mm exhaust studs, comes stock with oil cooler, improved auto cam tensioner, bigger oil pump... enough?
dont know how interesting it is for most 750 KZR-ers, but if you have questions, shoot.
and forgot, the best bit, it runs now like a brand new bike!
Attachment zr7.jpg not found
Last edit: 04 May 2016 14:29 by turboguzzi.
The following user(s) said Thank You: GPzMOD750
- Irish-Kawi
Re: zr7 motor in KZ750
04 May 2016 14:31
Very neat and great job to go through the effort to not just figure this out, but to also take a stab at doing it!
You mentioned the oil pump which is key, many may not be aware that you can actually swap in a ZR7 oil pump into a KZ750/650 motor. I know for a fact that the 750 motor works, and 99% certain that it fits the 650 as well since those are nearly identical. Great upgrade if you already have the engine out
Brett
Brett
All the gear all the time!
1985 Kawasaki GPz 750 (ZX750-A3) 15,000 original miles www.kzrider.com/forum/11-projects/601230...z750-refresh-project
Father - Husband - Bourbonr - Rider
- turboguzzi
04 May 2016 15:11 - 04 May 2016 15:22
well, i diid fit an zr7 pump to my gpz750/810 vintage racer ages ago...
still believe it's one of the reason it did 5 racing seasons withtout trouble !
from my racer build
kzrider.com/forum/2-engine/410994-gpz750...ing?start=120#429788
from my racer build
Last edit: 04 May 2016 15:22 by turboguzzi.
04 May 2016 15:22
Not that I'd ever do it, but I've been wondering if it was doable. Is that a 1980 KZ750E?
- turboguzzi
04 May 2016 15:29 - 04 May 2016 15:30martin_csr wrote: Not that I'd ever do it, but I've been wondering if it was doable. Is that a 1980 KZ750E?
yep, it's a 1980E, first year for the 750 model, now with a 2004 motor
Last edit: 04 May 2016 15:30 by turboguzzi.
The following user(s) said Thank You: JR
04 May 2016 15:38 - 04 May 2016 15:38
Thanks. What were the biggest fitment issues? I would have guessed the motor mounts would be the same, since the ZR engine number begins with KZ750EE. I'm assuming yours does.
Last edit: 04 May 2016 15:38 by martin_csr.
- JR
04 May 2016 15:45
Thanks for posting TG
Very interesting. Looks like a really good fit
Not that i'm planning anything major at the moment but great to know what can be done
- zukdave
04 May 2016 16:34
Fitting the ZR7 motor is the same as doing a GPz motor swap
into a 650/750.
As for the ZR7 oil pump it fit's all KZ650/750 and ZX750 motor's.
into a 650/750.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- Irish-Kawi
04 May 2016 16:37zukdave wrote: Fitting the ZR7 motor is the same as doing a GPz motor swap
into a 650/750.
Dave, especially with your history in the racing field and putting these motors to their limits and then finding the next weakest link
Inquiring minds want to know :woohoo:
Thanks,
Brett
04 May 2016 16:46
I've never heard of any oil related problems on the KZ650 engines. Mine has a mere 60,000 miles without ever having any oil problems, but Ronkz650 put 168,000 miles on his KZ650 without oil related problems. Ed
- Irish-Kawi
04 May 2016 16:54Absolutely believe that and know of the bulletproof reputation of these engines. That is why hearing about the severe oil issues on the Turbo version confused me. I know that there are some differences between the engines but I would struggle to imagine that they are so dramatic as to cause this level of concern, does that make more sense Ed?650ed wrote: I've never heard of any oil related problems on the KZ650 engines. Mine has a mere 60,000 miles without ever having any oil problems, but Ronkz650 put 168,000 miles on his KZ650 without oil related problems. Ed
Thanks,
Brett
04 May 2016 17:04
Makes sense to me. I wonder if the turbo 750 pushed things a bit beyond the design level of the oil pumps used in the 650 and normally aspirated 750 engines. For example - the KZ650-C1 made 64 hp while the 750 turbo GPZ makes 112 hp (see 1st link below). With that much oooomph that turbo 750 is probably putting a lot more stress on the internals. Some heavily modified turbo 750s put out as much as 282 hp! (see 2nd link below) I wonder what they use for pumping oil through those beasts; I can't believe they use the stock pump, so maybe there's a unit that could be easily used in the street turbo bikes if the stock units aren't up to the task. Ed
www.motorcyclespecs.co.za/model/kawasaki...pz750_turbo%2083.htm
www.750turbo.com/forum/viewtopic.php?f=9...cfe43309e10ecd320fd3
